Mentor
- 45,589
- 2,484
Because that page defined the angle a bit differently than I did. They defined [itex]\theta'[/itex] by constructing a line that starts at the top of the slit and is perpendicular to the "ray" drawn to the bottom of the slit. But in the "far screen" approximation, all the rays are treated as parallel, thus that line is perpendicular to all of them. (Just like in my definition.)Byrgg said:So you're saying that the angles are equal? Then why are they only approximated to be equal in the diagram in one of the links you gave me?
For reference, here's that page again: http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/fraungeo.html#c1
jtbell has kindly drawn a very useful diagram explaining the whole thing. Study it. (Maybe his explanation will click better than mine.)This is the problem, I can't find a way to add the phase differences that makes sense. When you said light from the top and bottom of the slit will exactly exactly cancel each other, you meant the light from the top and bottom halves of the slit, right?
In order for the light in the top half to cancel with the light in the bottom half, they must be exactly half a wavelength out of phase, but how is this achieved exactly?
In the meantime, let me try once more to describe what I'm talking about. Divide the slit into small segments, from top to bottom. How many? As many as we need to understand what's going on! Let's label the segments for reference, from top to bottom. I'm going to label the segments in the top half of the slit like this: T-1, T-2, T-3, etc. Similarly, I'll label the segments in the bottom half of the slit like this: B-1, B-2, B-3, etc. I hope this is clear.
Now the light from each segment goes out everywhere, hitting all points of the screen. But at any particular point on the screen, since it's at an angle to the slit, the light from each segment ends up just a little bit further out of phase than the segment above it, since the light has further to travel.
Now let's discuss a special point on the screen, the location of the first minima. That occurs when the angle is such that light from the first segment of the bottom half of the slit (B-1) travels exactly one half wavelength farther than the light from the top segment (T-1) by the time the light hits the screen. Since the light from B-1 and T-1 are exactly out of phase, they cancel out.
If T-1 and B-1 are out of phase, then it follows that T-2 and B-2 are also out of phase by the same amount. (Got that?) That means the light from segments T-2 and B-2 cancel out. Using this same reasoning, you should agree that every segment from the top half will exactly cancel out every segment from the bottom half. Thus, at the special angle where a minimum occurs, all the light from the slit cancels and the spot is dark.
Let me know if this is any clearer.
