I with a static fluids question
  • Thread starter Thread starter islanderfan
    Fluids Static
A physics problem involving a floating wooden block and a lead block was discussed, where the goal was to find the mass of the lead block when the wood is fully submerged. The initial calculations used Archimedes' Principle to relate the weight of the displaced water to the weight of the blocks. After some corrections, the participant calculated the buoyant force and derived the mass of the lead block to be approximately 1.01 kg. A miscalculation occurred due to incorrect arithmetic when subtracting the weight of the wood. The discussion emphasized the importance of careful calculations in solving static fluid problems.
islanderfan
[SOLVED] i need help with a static fluids question
A block of wood of 1.8 kg mass floats on water with 64% of its volume submerged. A lead block is placed on the wood and the wood is then fully submerged. Find the mass of the lead block.
Fb = pvg
(1000)(.64v) = Pblock (.36v)
Pblock = 1777.78
p = m/v...m/p = v
1.8/1777.78 = .001 m^3 = total volume
i have no clue what to do next, or even if what i have done so far is correct. please anyone who can help me?
Use Archimedes' Principle.
Your eqn under attempt is wrong.
Weight of block = Fb_up = wt of water displaced = (64/100)*vol of block*density of water
=> 1.8*9.8 = 1000*0.64*V. You get V
Applying the same idea, can you do the 2nd part. Remember, the whole block plus the lead is being supported by the wt of the water displaced by block alone.
ok i did what you said. i obtained a v of .02756... and plugged that into Fb = 1000*(.02756...)*9.8, which gave me a Fb of 270.1125. I set this equal to mg and divided by 9.8 to get a final answer of 27.56. I then subtracted the 1.8 kg of wood and for some reason I'm wrong. Can you find my error? thanks soo much
I'm getting the mass of lead block as 1.01 kg.
I'm a bit tired of calculating, so if that's the correct answer, then you check your calc. Otherwise, we'll have to identify the source of error.
haha I've learned to never blame the calculator, blame the user ;]. it was my own careless arithmetic error that caused me to get the wrong answer. when i got down to 27.5625 i subtracted 1.8 kg instead of subtracting (1.8*9.8)N and so i got an answer that was too large.
thanks SO much for the help, i really appreciate it!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
