I: X'->X the identity function with topology
tomboi03
Let X and X' denote a single set in the two topologies T and T', respectively. Let i:X'-> X be the identity function
a. Show that i is continuous <=> T' is finer than T.
b. Show that i is a homeomorphism <=> T'=T
This is all I've got.
According to the first statement... X \subset T and X' \subset T
a. if i is continuous... each open subset V of X' the set i^-1 is an open subset of X
T' is finer than T means... T \subset T'.
i don't know where to go from here...
b. if i is a homeomorphism...
then... i is... a bijection therefore the function and the inverse function are continuous.
i and i^-1 are continuous. each open subset V of X' the set i^-1 is an open subset of X
if T' = T... then...
i don't know where to go from here either...
can someone help me out?
Thank You,
tomboi03
don't know a heap about this stuff but would think you were pretty close, will have a try...
so
X \in T
X' \in T'
for a)
prove ->
i is the identity X' -> X
continuous means preimage of an open set is open
so given V\in T (as the topology contains all the open sets)
then V' = i-1.V is open
so V' is in T'
but
V' = i.V' = i. i-1.V = V (little sketchy about this part??)
so
if
V\in T
then
V is in T'
so T \subseteq T'
now need to prove other direction...
T' "finer" than T means that any open set in T is an open set in T' (but there may be open sets in T' that are not in T).
Suppose T' is finer than T. If U is an open set in T, then i-1 maps it back to itself, which is an open set in T' so the identity map is continuous.
Suppose i is continuous. It U is an open set in T, then i-1 maps it back to itself, which, because i is continuous, is open and so in T'. Thus, every member of T is in T' and so T' is finer than T.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
