IBM PC XT 256K Memory - How Does It Work?
  • Thread starter Thread starter curiousguy23
    pc Ram
The discussion revolves around the memory capacity of the IBM PC XT, specifically addressing how the board can accommodate multiple memory chips while being stated to support a maximum of 256K of memory. Participants explore the technical specifications and configurations of the motherboard.
  • One participant notes that the IBM PC XT technical reference indicates a maximum of 256K of memory, despite the presence of 36 memory chip sockets.
  • Another participant mentions that the XT originally shipped with a configuration supporting 256K on the motherboard, but could achieve up to 640K with expansion cards, citing historical configurations.
  • A different participant points out that the visible memory chips in the provided image suggest a total of 864KB, raising questions about the board's actual memory handling capabilities.
  • One participant acknowledges a misunderstanding regarding the memory configuration.
  • Another participant speculates that the total memory could be 768KB with parity, expressing uncertainty about the memory map differences between the XT and AT models.
Participants express differing views on the memory capacity and configuration of the IBM PC XT, with no consensus reached on how the board can support the number of chips present versus the stated maximum memory capacity.
There are unresolved questions regarding the interpretation of the memory chip configurations and the relationship between the number of chips and the maximum memory capacity stated in the technical reference.
curiousguy23
Hi All,
i was looking at the IBM PC XT technical reference and it states that the board can take a maximum of 256K of memory. If you look at the schematic you can then see 36 sockets for memory chips and if you see this picture of it
http://upload.wikimedia.org/wikipedia/de/1/11/PCXTMainboard01.jpg
You can see that the memory chips are ud61256 256k by 1 DRAM chips. How can the board support all these chips if the max it can handle is 256k?
Thanks
Computer science news on Phys.org
640kB ought to be enough for anybody. If memory serves me well that was the limit for XT. Doesn't mean all were equipped with 640, early models (and/or cheap ones) had less.
Edit: taken from wikipedia:
There were two widely used configurations of the XT motherboard. The first could support up to 256kB on the motherboard itself (four banks of 64kB chips), with a maximum of 640kB achieved by using expansion cards. This was the configuration the XT originally shipped in. The second configuration - introduced in stock units in 1986 - could support the whole 640kB on the motherboard (two banks of 256kB chips, two banks of 64kB), had the later revision AT-compatible BIOS with a faster booting time, as well as support for 101-key keyboards and 3.5" floppy drives. The earlier configuration could be adapted to 'late' configuration after a couple of minor modifications.
Not sure you got what I am saying. Even if the max was 640kB , on the photo you can clearly see 27 chips each with 256Kbits of DRAM. This would amount to 6912Kbits in total and thus 864KB. From what I can see that board is equipped with more memory than it can handle, or I might be seeing it wrongly.
Yep, I misunderstood.
It's probably 768KB with parity. I don't recall if the memory map of the XT and what it allowed versus the AT.
11K
