Ice added to water at 273K, calculate new ice mass
A user seeks help calculating the new mass of ice when 0.1 kg of ice at 263K is added to 1 kg of water at 273K. They express confusion about using the heat transfer formula since the water is already at 273K, questioning if there's an enthalpy formula for this scenario. The discussion clarifies that the heat of melting can be applied in both directions for phase changes, and the user successfully calculates the mass of ice after heating. It is confirmed that if both ice and water are at 273K, no phase change will occur without external heat exchange. Understanding these principles helps resolve the user's confusion about phase transitions.
mertzi
Member warned about lack of template
Hi! I'm new here and I can't find anything helpful through google so I thought I'd give PF a try. Sorry for not using the template fully but I have no ideas on how to solve this problem.
1. 0.1kg ice at 263K is added to 1kg water at 273K. Calculate new mass of the ice.
2. I know how to do this calculation if the water temperature is higher than 273K, but then I got this problem where the water is already at 273K (0°C) therefore no change in temperature so I can't use Q=c⋅m⋅ΔT or at least I can't get my brain around how. Is there an "opposite direction" enthalpy formula? As I have understood it this situation will actually increase the mass of the ice since energy will be released when the ice is heated to 273K.
3. Can I do this the other way around i.e. calculate how much water needs to turn to ice to heat the ice to 273K?
ΔQ=cice⋅mice⋅ΔT = 2.2kJ/(kg⋅K)⋅0.1kg⋅10K = 2.2kJ
Then
2.2kJ = m⋅Lwater
m = 2.2/332 ≈ 6.6⋅10-3kg
mice total = mice 0+mice 2 = 0.1+6.6⋅10-3 = 0.1066kg
Thanks!
DrClaude said:
Look up latent heat.
thank you, I'm uncertain if this is the same we have been thought about enthalpy because in our tables we have these specific formulas for phase changes with lower case l. Like ΔQ=lmm and ΔQ=lvm (m=melt, v=vaporize).
I've made an attempt at a solution in my OP, can I use this method for any phase change regardless of "direction"?
I would advise against editing the OP. Things are easier to follow if the development can be seen in the replies.
Yes. For example, the heat of "melting" can be used both for melting and for solidification.
Thank you
Here is my first attempt on a solution, I suspect something is missing.
Then
2.2kJ = m⋅Lwater
That looks fine.
Likes mertzi
DrClaude said:
That looks fine.
Woo hoo, thank you! Knowing these properties go any direction clears up a lot of confusion. One final question just to see if I've understood everything correctly. If both ice and water is 273K from the start then nothing will happen?
Correct. At the temperature of the phase transition, both phases coexist. The amount of one phase or the other can then only change if there is exchange of heat with something outside the system.
Likes mertzi
