How is the Ideal Gas Law Derived from Temperature and Pressure Relationships?
The Ideal Gas Law, expressed as PV = nRT, can be derived from the relationships between temperature, pressure, and volume. The discussion highlights the manipulation of equations involving temperature (T), pressure (P), and volume (V) to establish the proportional relationships that lead to the law. Specifically, it emphasizes that at constant volume, pressure is proportional to temperature, and at constant pressure, volume is proportional to temperature. The mathematical derivation involves the equations p2xt1/p1 = v1xt2/v2 and the manipulation of these to isolate the relationship between P and V.
  • Understanding of the Ideal Gas Law (PV = nRT)
  • Basic algebra for manipulating equations
  • Familiarity with thermodynamic concepts of pressure and volume
  • Knowledge of proportional relationships in physics
  • Study the derivation of the Ideal Gas Law from kinetic molecular theory
  • Explore the implications of the Ideal Gas Law in real-world applications
  • Learn about deviations from ideal gas behavior in real gases
  • Investigate the relationship between temperature, pressure, and volume in different states of matter
Students of physics, chemistry, and engineering, as well as professionals involved in thermodynamics and fluid mechanics, will benefit from this discussion on the derivation of the Ideal Gas Law.
Kathhhriine
In the question, it was first asked to state the relationship between p1, p2, t1 and t', and v1, v2, t' and t2. This was found to be p1/t1=p2/t' and v1/t'=v2/t2. Further, it is asked to use these relationships to deduce that for an ideal gas PV=KT where K=constant, this is the part i dont understand.
For further understanding of the question, the question states this: "The ideal gas is held in a cylinder by a moveable piston. The pressure of the gas is p1, its volume is V1 and its kelvintemperature is T1. The pressure, volume and temperature are changed to p2, V2and T2 respectively." from p1 t', the volume is kept constant, giving p2, t' v1, and from v1, t', pressure is kept constant, giving v2, t2 and p2.
PV=KT
I figured that T' is a common factor for both relationships and from there deduceted that T'=p2xt1/p1=v1xt2/v2. However, I don't understand how that can be further manipulated to PV=KT.
Since, at constant volume, pressure is proportional to temperature, you can write $$P=f(V)T$$ and since at constant pressure, volume is proportional to temperature, you can write $$V=g(P)T$$ So, if you divide one equation by the other, you get $$\frac{P}{V}=\frac{f(V)}{g(P)}$$or$$Pg(P)=Vf(V)$$So the left hand side is a function only of pressure and the right hand side is a function only of volume. Mathematically, what is the only way this can happen?
You have p2xt1/p1=v1xt2/v2 . Divide both sides of the equation by (t1t2) and muliply by (p1v2).
  • · Replies 33 ·
10K
