Ideal Gas: Non-Uniform Conditions Explained
  • Thread starter Thread starter mikeph
    Gas Ideal gas
In a fixed-volume container filled with CO2, heating the edges creates a controlled environment for temperature, volume, and molecule number, with pressure determined by the ideal gas equation. However, if temperature is non-uniform, it leads to variations in pressure and density, challenging the ideal gas assumptions. The ideal gas equation is most accurate at thermal equilibrium, and deviations occur under high pressure or extreme temperatures. When the ideal gas law fails, no single equation universally applies, but alternative models like the Van der Waals equation offer improved approximations for gases nearing liquefaction. Understanding these limitations is crucial for accurately describing gas behavior in non-equilibrium conditions.
mikeph
Hi,
If I have a container with fixed volume, and fill it entirely with a known quantity of CO2, and then heat the edges, I should be right in saying I have under my control the temperature, volume and molecule number, and the pressure is fixed by the ideal gas equation (assuming the assumptions of this model are valid).But what if these values are non-uniform? Does the restriction still apply? Can I specify temperature, pressure, volume and molecule density fields, and is there some generalised for of this ideal gas equation?
Or can I say that in theory, the restriction has been lifted, and does not apply for a container with a gas which is not in thermal equilibrium.
Thanks,
Hello Mikey .the volume of the gas will be the volume of the container and if the container is tightly sealed the number of molecules is fixed.If there is a temperature variation throughout the container there will be a corresponding pressure and density variation.The ideal gas equation is followed more closely when the gas reaches thermal equilibrium but it should be remembered that the equation is an approximation only and becomes more in error as the pressures rises and if the temperature approaches values where the collisions become exciting or ionising.
Ok- thanks for your reply. Can I ask as a further question, if the ideal gas equation breaks down under those conditions, does a different equation (whether we know it or not) "take over"? Or am I free to vary the fields in whatever way I like, as long as I don't forget that I no longer have thermal equilibrium?
As far as I am aware there is not an equation which applies closely under all conditions but there are equations that are better approximations.Van der Waals equation is an improvement on the ideal gas equation particularly for when gases get close to liquification.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
