Identification of group 2 metal salts
The discussion revolves around experiments conducted with two unknown group 2 salts, labeled X and Y. When dilute NaOH was added, Y formed a precipitate while X turned colorless, indicating that Y likely contains an ion that is insoluble in hydroxide, such as beryllium or magnesium. Further tests with AgNO3 and BaCl2 were suggested to identify potential anions in the salts. The participants noted that the concentration of NaOH used is crucial for accurate interpretation, and they discussed the solubility characteristics of various group 2 salts. It was proposed that Y could be magnesium chloride or magnesium sulfate based on the precipitate formation, while the identity of X remained uncertain, with suggestions that it might be barium sulfate, although this was later questioned. Overall, the conversation highlighted the importance of understanding solubility rules and conducting further tests to identify the salts accurately.
david18
Hi, I carried out a couple of experiments with unknown group 2 salts; X and Y
I added dilute NaOH to each of the salts which were now mixed with 1cm^3 of water; Y formed a precipitate (initially the solution was colourless as the solute had dissolved) whilst X turned colourless (X's solution was initially insoluble and was therefore a ppt before)
What conclusions could I draw from these observations? I think it might have something to do with Y having an ion that is insoluble when added to OH (ie Be and Mg) and vice versa... but I am not too sure...
Another test was adding AgNO3 + nitric acid, and in another I added BaCl2 - what could these show me?
Chemistry news on Phys.org
Very difficult question with only these data.
1. X and Y are necessarily salts or can also be oxides/idroxydes?
2. group 2 include also 2b, that is Zn, Cd, Hg?
3. How dilute is NaOH? Can you specify better the concentration or the pH of the solution?
About substance X: an insoluble group 2 salt that dissolves with diluted NaOH, have I understood correctly?
Berillium idroxyde, carbonate, phosphate are insoluble but dissolves in high alcaline solutions ( not very diluted, then). The same with Zinc, for example.
About Y, there are many elements and many salts for every of those elements which dissolve in water and precipitates with OH-:
Mg (alogenides, nitrate, sulfate), Ca (alogenides, nitrate), Cd (alogenides, nitrate, sulfate), Hg (Hg(II) alogenides, nitrate).
Be and Zn precipitates with diluted sol. of OH- and re-dissolves in high con. of OH-.
AgNO3 will help you to find out if there are halide ions (chloride, iodide, bromide,..) in the salts X and Y.
BaCl2 will tell you if sulphate is present.
These two tests determine the anions.
the test with NaOH will help to distinguish the cation.
and i think Y is MgCl2 or MgSO4. you will know that when you test the anion. A white ppt. is formed when you add the Mg salt to NaOH.
This appears to be a school lab experiment. simple and easily available reagents are involved.
Kushal said:
i think X is BaSO4. BaSO4 is insoluble in water, but when you add NaOH, it dissolves.
I don't think so. Which should be the reaction?
o yeah, of course, X is NOT BaSO4, i will correct that right here. i think more information is required. sorry
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
