Identify Bottles: Lead Nitrate, HCl, Copper Sulfate, Sodium Carbonate
  • Thread starter Thread starter TT0
The discussion focuses on identifying four chemical substances based on their reactions. Bottle 1 is confirmed as lead nitrate, Bottle 2 as hydrochloric acid, Bottle 3 as sodium carbonate, and Bottle 4 as copper sulfate. The reactions between these substances produce specific precipitates or gases, with sodium carbonate reacting with hydrochloric acid to produce carbon dioxide. The participants clarify that hydrogen gas does not evolve when HCl is added to lead nitrate or copper sulfate, as carbon dioxide and water are the products instead. Overall, the identification and reactions discussed are deemed correct.
TT0
Identify the bottles
2. Homework Equations
Bottle 1 is lead nitrate as lead is the only metal that will form a precipitate with the other anions.
Bottle 3+4 = copper sulfate + sodium carbonate -- because it produces blue precipitate
Bottle 2+3 = hydrochloric acid + sodium carbonate -- as acid + metal = salt + hydrogen gas.
This means sodium carbonate is bottle 3, hydrochloric acid is bottle 2, and copper sulfate is bottle 4. Can someone check this?
If this is correct, out of interest, why doesn't hydrogen gas evolve when HCl is added to lead nitrate and copper(II) sulfate?
Cheers!
2+3 : Sodium carbonate is not a metal and the gas is not hydrogen.
That should also explain why HCl does not produce a gas with PbNO3 or CuSO4
Likes TT0
I see, I forgot. CO2 and water are evolved, not H2! Other than that, is the rest of the answers correct?
Cheers!
If I have deduced correctly from your statements, you are saying;
1 - PbNO3
2 -HCl
3- Na2CO3
4 - CuSO4
So that means;
1 & 2 is lead nitrate + HCl -> white precipitate of
1 & 3 is lead nitrate + sodium carbonate -> white precipitate of
1 & 4 is lead nitrate + copper sulphate -> white precipitate of
2 & 3 is HCl + sodium carbonate -> gas produced = CO2
2 & 4 is HCl + copper sulphate -> no visible reaction
3 & 4 is sodium carbonate + copper sulphate -> blue precipitate of
all plausible, so you are correct.
You could write out the equations for each, apart from the no reaction, if you wanted to make clear what was happening.
Likes TT0
I see, cheers!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
