Identify the following motions as positive or negative accelerations
The discussion focuses on determining whether two motions represent positive or negative acceleration. The first motion, changing from 10 m/s [W] to 20 m/s [W], is identified as positive acceleration, while the second motion, changing from 20 m/s [W] to 10 m/s [W], is viewed as negative acceleration or deceleration. Participants emphasize that the sign of acceleration is determined by the change in velocity, regardless of the chosen directional convention. It is suggested to keep velocity positive and denote direction explicitly to avoid confusion. Understanding these concepts is crucial for correctly analyzing motion in physics.
selcouth
An object changes its velocity from 10 m/s [W] to 20 m/s [W] in 4.0s.
An object changes its velocity from 20 m/s [W] to 10 m/s [W] in 4.0s.
N/A
I'm thinking the first one is positive acceleration and the other one is negative acceleration (people also say deceleration but my teacher told us to use the term negative acceleration) because if you're moving west, west is negative so isn't -10 greater than -20? I'm awful at physics so I don't know if I'm thinking this through correctly.
West is only negative if you define it to be so.
It would be good practise to see how you get the same answers for this problem whether you take west to be negative or positive.
You put N/A for relevant equations, but you could have put an equation relating acceleration to change in velocity which would really help with the problem.
Acceleration is proportional to change in velocity, and remember than when you see "change" in basic physics you can usually replace that with "final minus initial"
So if your initial velocity is -20m/s and your final velocity is -10m/s what was the change in velocity? Take the sign from that result and that should tell you the sign of the acceleration
Actually on second thought you should probably just treat it as positive.
Getting a positive acceleration on an object traveling in the negative direction is still causing the object to slow down and I think the point of this problem is for you to call that negative acceleration.
So for this sort of problem just keep velocity positive and indicate direction like they did in the question: [W] or [E]
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
