Alfcon
- 1
Hi, if I have 3 naded wires copper, Tin and Lead wrapped into one cable and I run 12v through it how do I work out the amount of resistance I get and the total voltage at the other end?
Alfcon said:Hi, if I have 3 naded wires copper, Tin and Lead wrapped into one cable and I run 12v through it how do I work out the amount of resistance I get and the total voltage at the other end?
Copper wires are known to have excellent electrical conductivity, thermal conductivity, and malleability. They are also resistant to corrosion and have a low melting point.
Assuming the wires are pure copper, each wire would have the same number of electrons. Copper has 29 electrons in its outermost energy level, so 3 wires would have a total of 87 electrons.
The thicker the copper wire, the lower its resistance and the higher its conductivity. This is because a thicker wire has a larger cross-sectional area, allowing more electrons to flow through it at a time.
Yes, copper wires can carry both AC (alternating current) and DC (direct current) currents. This is due to their excellent electrical conductivity, which allows electrons to flow in either direction.
It depends on the specific application and the thickness of the wires. Generally, thicker wires are used for household wiring to handle higher currents and reduce the risk of overheating. It is best to consult a professional electrician for proper wire sizing and installation.
