If light-speed is invariant,why RoS exist?
  • Thread starter Thread starter ash64449
ash64449
This is a question from Einstein's thought experiment.
This thought experiment is found in this article: http://www.marxists.org/reference/archive/einstein/works/1910s/relative/relativity.pdf
For those who know that thought experiment,i would like to ask a few questions.
To an observer outside two lightning striking the train are simultaneous.
Well,we know that light speed is invariant,it travels at the same speed regardless of whether the observer is moving or not.
Well,there is an observer in train.
Train is moving in uniform motion. Since rest and uniform motion are indistinguishable in his reference frame,he considers himself as at rest. lightning strikes are simultaneous in outside frame,we know that light travels at the same speed. So light from both the lightning strikes must reach the observer in train in the middle at the same time,because light speed is invariant regardless of the motion of the train. So Observer in the middle of the train must come to the conclusion that lightning strikes are simultaneous.
Yet Einstein's thought experiment says that this cannot happen. Why?
Draw a space-time diagram, from the stations point of view. The two light signals will meet at the midpoint in the station frame. The train will have moved since then, however, so that won't be the midpoint of the train.
The observer in the train is moving toward the lightning strike ahead and moving away from the lightning strike behind. This observer is not in the middle.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
