If the atmospheric pressure is 0.975 atm
To determine the pressure of the enclosed gas in an open-tube manometer with an atmospheric pressure of 0.975 atm and a height difference of 52 cm, a proportion can be set up using the conversion factor of 760 torr for 1 atm. The calculation yields a pressure of 741 torr for the gas. However, the density of the gas may also be relevant for further calculations. The height difference in the manometer must be considered to accurately assess the gas pressure. Understanding these principles is essential for solving the problem correctly.
priscilla89
If the atmospheric pressure is 0.975 atm, what is the pressure of the enclosed gas when its an open-tube manometer and the h is 52 cm?
I know you would have to set up a proportion. I was thinking
.975 / 1 = x / 760
x = 741 torr
But you will need the density of this gas, right?
.975 / 1 = x / 760
x = 741 torr
But you will need the density of this gas, right? I know we'll have to use the height but I don't know how.
This question is at this website below, its on pg 399 Q 15 i. I will appreciate the help for just one question at least.
http://www.chemistry.ohio-state.edu/~rzellmer/chem122/homewk/homewk9/122ch10_exer9.pdf"
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
