Ratch said:
sophiecentaur,
A capacitor always has a dielectric.
How about
these? In practice, of course, there is never 'nothing' between the plates of a capacitor but on these jobbies, ε
r is reckoned to be as near as dammit to unity. A 'dielectric' is a material that polarises - not a vacuum.
This MIT link defines Polarisation as charge separation, in any form so my use of the word is justifiable, I think.
I disagree. There will be no current between two floating caps. Try energizing two caps, and put a ammeter between the two plates to see if there is any current.
I will try a diagram, to show you what I mean about the Capacitors involved when I have time - Power Point is OK but slower than writing and ranting for me. You object to the used of the word 'Parasitic' on the grounds that they are only relevant at HF. But that's the whole point. They are small but if they work at HF then they have a finite effect at all frequencies and at DC.
This is hardly worth answering, it's so obvious. I was clearly talking about what would happen at the start of this process - when you add the battery or start to move the (original) wire in a field. If you acknowledge that there will be a charge separation / difference then some current was flowing at one time.
You have clearly nailed this particular flag to your mast and are sticking to it but can you quote me this as a generally used term? 'Correctness' is something that needs a bit more support than just what you are saying. But, again, is this relevant to the main discussion? We can usually describe the World in more than one way. Energy is a pretty good way to describe and predict things (I am a big fan, in general) in Physics but Forces, Masses, Charges and Impedances are often used more conveniently. Perhaps this is why we learn and then use Q=CV so often - despite the fact that V is Energy per Unit Charge.
Energized simply means "charged with energy".
A bit of tautology, (or is it self-referencing?) here, I think. From what I can find, the term 'energised' seems to be used for circuits in which a current is flowing continuously but the word is used very freely and imprecisely so I don't think it is any better than 'Charged', aamof.
