If you crank a generator in space
Electricity generation relies on the movement of electrons, which are not sourced from ambient air but are part of the circuit itself. A generator functions similarly to a water pump, drawing electrons in one wire and pushing them out another at higher voltage. If electrons are continuously removed from the circuit, appliances like light bulbs will cease to function. In alternating current (AC) systems, the generator causes electrons to vibrate rather than move in a single direction, maintaining the flow without depleting the electron supply. Understanding these principles clarifies that generators can operate in space, as they rely on the existing electrons in the circuit.
linux kid
I am confused about where the electrons come from when electricity is generated. Is it from ambient air? So this means A generator would not work in space?
They come from your appliances.
A generator works like a water pump. Electrons are sucked in at one wire, and squirted down the other wire at higher electric pressure (a la voltage). It would all stop working if electrons weren't able to recirculate back again (indeed, your lights go off whenever you break open this circuit).
so there must be a certain amount of electron available. And what if you somehow kept removing those electrons what would happen to the appliance (eg. light bulb)?
the point is that you can't remove the electrons. the best you can do is try to pump a lot of them up to one end of a wire (but this is hard to do because it leaves the other end positively charged, so the electrons are attracted to move back again somehow), and your appliance just stops the moment the electrons aren't moving through it anymore.
..actually, what I've described is the simpler case of DC. In the real world of AC, what the generator does is more like making the electrons in the connected wire vibrate (not significantly moving electrons in any direction overall, not going anywhere, hence not coming from anywhere).
Oh...I get it now. Thanks.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
