If you diged so deep into the earth
  • Thread starter Thread starter linux kid
    Earth
The discussion centers on the hypothetical scenario of digging a tunnel to the Earth's core and the implications of such an endeavor. It highlights the impracticality of reaching the core due to extreme temperatures that would melt any tools and protective gear. The conversation explores the definition of a volcano, questioning whether creating a tunnel to the center of the Earth could result in volcanic activity. It notes that magma reservoirs are typically located closer to the surface, making it unnecessary to reach the core for magma flow. The challenges of maintaining an open tunnel are also discussed, particularly the risk of collapse given the Earth's thin crust and the liquid nature of the mantle. Additionally, misconceptions about the mantle's solidity are addressed, emphasizing its elastic properties. The potential dangers of reaching the outer core, including the risk of being engulfed by liquid iron, are also mentioned, underscoring the complexities of such a deep excavation.
linux kid
...until you reached the core, what would happen? Would you have created a new volcano? or...
Oh my goodness. Where do we start?
I can assure you your little shovel will have melted before you reach the core.
Here's a place to start.
http://www.mhhe.com/physsci/astronomy/arny/student/webtutor/earth_core/index.htm
If you got a "very expensive" shovel and a "very expensive" body suit that didn't melt, nor' did you die in the process.
Here's a thought -> What is the very definition of a volcano? If you did create a tunnel to the center of the earth, would it create the definition of a "volcano"?
*EXAMPLE* Let's say the very definition of a Volcano is that it has to shoot out lava/magma (This isn't the definition by the way). If you created such a tunnel, would there be pressure to shoot out lava or would it just flow out?
You wouldn't need to go to the core to find magma. Resevoirs of magma are usually fairly close to the Earth's surface.
Now, how would you keep your hole from continuously filling back in? If you thought OSHA got in a tizzy about proper supports if your hole gets larger than waist-deep, just wait until they hear about plans to dig to the center of the Earth! :smile:
This is what happens when you dig too deep.:cool:
Consider that the Earth's crust is eggshell thin in comparison to the Earth's radius. It is impossible to dig a hole beyond the crust simply because the mantle is not solid, how do you dig a hole in liquid?
It seems like it would be possible to open a path for magma to flow to the crust. It is not clear to me how wide a hole would have to be for this to happen. While the mantle is liquid it is very viscious so would not flow through just any hole.
If you and your little shovel were to dig a hole that deep, the only thing you'd have in greater excess than hot rock would be spare time.
Start digging and find out!
Just kidding.
Some misconceptions here, the mantle is thought to be solid but parts are elastic.
But you really get in trouble when you hit the outer core.
The liquid iron would be forced up, while the pressure is released whilst you float on liquid iron, you will go up too, until you bump your head against the plastic astenosphere, which started to fill up your hole.
Source: http://www.enchantedlearning.com/subjects/astronomy/planets/earth/Inside.shtml
