IFORT Coding Problem (Simpson's Rule)
  • Thread starter Thread starter Physics_Math
    Coding
The discussion centers on implementing Simpson's Rule in Fortran to approximate the integral of the function f(x) = exp(-x)*sin(x) over the interval [0,10]. The program structure includes a main program and a subroutine for integration, where the step size h is halved iteratively to improve accuracy. An error threshold epsilon is used to determine convergence, with the condition that the difference between new and old integral estimates must be less than a specified fraction of the new estimate. A key issue identified was the need to correctly accumulate values in the loop, specifically by updating the sumodd variable. The problem was resolved by adjusting the loop to include the line sumodd = f(x) + sumodd, leading to correct results.
Physics_Math
For a function f(x) over the interval [a,b], simpson's rule approximates the defenite integral:\intf(x) dx = h/3*[f0 + 4(f1 + f3+ ...+ f2n-1) + 2(f2 + f4 + ... + f2n-2) + f2n]
where h = (b-a)/n
fi is f(a + i*h)
Given an error epsilon, I need to write an executable program using IFORT that will find this integral using the simpson's method for f(x) = exp(-x)*sin(x) on [0,10] which converges if
new integral - old integral < new integral*eps
obvioulsy a loop will be in this program. What you have to do is cut the h in half every time to get a better approximation. And each time you have to change the odd fi to the even fi, and vice versa.
see the above equation
Here is my program.
PROGRAM Simpson_Rule
IMPLICIT NONE
REAL(8) :: eps, a, b, integral, f
EXTERNAL f
eps = 1.0d-10
a = 0.0d0
b = 10.0d0
CALL Simpson_Integrate(f, a, b, eps, integral)
PRINT *, integral
STOP
END PROGRAM Simpson_Rule
SUBROUTINE Simpson_Integrate(f, a, b, eps, integral)
IMPLICIT NONE
REAL(8) :: a, b, integral, f, eps, h, x, sum, sumeven, sumodd,
& integral_old, end_points
INTEGER :: i, n_sum_add, ne
h = (b-a)/2.0d0
sum = f(a) + f(b)
end_points = sum/3.0d0
x = (a+b)/2.0d0
sumodd = f(x)
integral_old = h*end_points + 4.0d0*sumodd*h/3.0d0
n_sum_add = 2
do ne = 1, 40
sumeven = sumeven + sumodd
sumodd = 0.0d0
x = a + h/2.0d0
do i = 1, n_sum_add
sumodd = f(x)
x = x+h
end do
h = h/2.0d0
integral = h*end_points + (4.0d0*sumodd + 2.0d0*sumeven)*h/3.0d0
print*, 2**ne, integral
if (abs(integral-integral_old) < abs(integral)*eps) return
integral_old = integral
n_sum_add = n_sum_add*2
end do
print*, "Integration has not converged"
return
END SUBROUTINE Simpson_Integrate
real(8) function f(x)
IMPLICIT NONE
REAL(8) :: x
f = exp(-x)*sin(x)
return
end function f
When I execute, i don't get sensible results. Any help is appreciated
The first thing I noticed is that fortran might not like having a function named the same as a variable.
I was confused when you wrote f(a) + f(b); I originally thought that f was an array. Try changing the name of that function.
I don't believe that is the problem. I've done this same type problem with Trapezoid rule and it works just fine with the same function defined as I have done in the program shown above.
Ok I actually solved this problem on my own. In the loop I need:
and then all is swell.
:D
