Ignore voltage reference on resistors?
The discussion revolves around solving a circuit problem from Schaum's Outlines, specifically addressing the confusion about ignoring the voltage reference of V3. It clarifies that the voltage reference can be adjusted based on the direction of current flow, impacting the calculation of voltages across resistors. The participants emphasize using Kirchhoff's Voltage Law (KVL) correctly and suggest that summing resistances and multiplying by current simplifies the process. They also note that changing voltage references is acceptable as long as the final answer aligns with the problem's requirements. Overall, the conversation highlights the importance of understanding voltage references and current direction in circuit analysis.
rp1242
I'm working on 3.19 from Schaum's Outlines: Basic Circuit Analysis (not homework).
The problem can be found at this http://books.google.com/books?id=EP...resnum=1&ved=0CBMQ6AEwAA#v=onepage&q&f=false".
I'm confused about why you're supposed to ignore the voltage reference of V3 in this case. I'm looking at my circuits textbook from school and it says to subtract voltages when negative signs are encountered first and add voltages when positive signs comes first (KVL).
Can anyone help me?
Its because that voltage reference ignored the direction of the current flow. In other words, Voltage V3= -I*6 = -1.8
Then, doing a Kirchhoff...
Vab= VR2+5-V3+V4-8
Vab= (15*0.3)+5-(-1.8)+(8*0.5)-8
Vab= 5.7 Volts
But that's not the best way to solve this kind of problem.Remember that n elements in series share the same current, so if you sum the ohmic value of all the resistors, multiply it by the current in the circuit and then doing the algebraic sum of the voltage sources you got your answer. This way the only reference you have to take in consideration is the one of the voltage you are after. Make sure your current 'enters' by the positive reference.
Lets do the same example using my logic, this time using the left side of the circuit since it has less components.
10 ohms + 11 ohms = 21 ohms
21ohms multiplied by -0.3Amps = -6.3V
-6.3 plus the voltage source 12v = 5.7V
The current in this case is -0.3 becase it was initially defined in the other direction, and the voltageAB is defined such as the current 'enters' by its positive reference.
If the voltage had been defined with opposite references, it would have been like:
21*0.3= 6.3V
6.3 - 12 = -5.7V
In this case the voltage is defined such as the current 'enters' by its negative reference. Which is the same direction it was initially defined.
Finally, you can always change the voltage references acording to you likings and then change it back as what the problem asked for. So in that same problem you can define V3 with the opposites references and simply solve the equation the book provided. Though keep in mind that if you were also asked for the voltage V3 and you answered it with the opposite reference it would have been a wrong answer. In the original circuit V3 = -1.8Volts
The equation used by the book defined V3 as 1.8 Volts.
Thanks, Rainier. That helps a lot!
For some reason, I thought that the voltage reference symbols indicated whether an element supplied or consumed power. This clears up my confusion about "resistors supplying power."
Thanks again!
You could add up the voltages going clockwise around the circuit:
Voltage = 12 V - 5 V + 8 V = 15 volts
Then add up the resistances
Total resistance = 10 + 15 + 6 + 8 + 11 = 50 ohms.
So, the current = 15 volts / 50 ohms = 0.3 amps flowing clockwise around the loop.
Voltage drop across any resistor = 0.3 amps * R
So voltage drop across the 6 ohm R = 0.3 amps * 6 ohms = 1.8 volts,
but the positive end of the resistor is at the top in the diagram because the current is flowing clockwise and enters this end first.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
