ImageShack® - Host Photos & Videos Online
  • Thread starter Thread starter gomes.
    Photos Videos
The discussion revolves around solving a boundary value problem using four basic solutions related to wave equations. The user is struggling with parts (e) and (f) of the problem, specifically in selecting between two remaining solutions after eliminating others based on boundary conditions. The response emphasizes the need to correct the boundary conditions to proceed with finding solutions for both parts. For part (e), it suggests comparing the boundary condition for y(x,0) with the remaining equations to identify a valid solution. In part (f), it advises applying the boundary condition y(L,t)=0 to derive a condition for k and subsequently finding a value for c using dy/dt at t=0.
gomes.
ImageShack® - Online Photo and Video Hosting
Im a bit stuck at part (e) and (f)
The 4 basic solutions are:
sinkx*coskct
sinkx*sinkct
coskx*coskct
coskx*sinkct
I got the 4 boundary conditions as:
y(0,t)=0
y(L,t)=0
y(x,0)=sin (2pi/l)x
dy/dt at t=0, =0
For part (e), I could eliminate coskx*coskct and coskx*sinkct from y(0,t)=0.
How do I choose between the other 2 solutions?
for part (f)
How do I do it? Thanks.
The last two of your boundary conditions are wrong.
If they are corrected solutions for parts (e) and (f) can be found. Even if they are not corrected a solution can be found for part (e), but not (f).
After the boundary conditions are corrected:
part (e): Compare the boundary condition for y(x,0) with the remaining two equations. Only one can have finite solutions for all possible values of x.
part (f): Apply the boundary condition y(L,t)=0 to the singled out solution and find a condition for k. Then use the boundary condition for dy/dt at t=0 to find a value for c. If you have k and c, you have the frequencies.
Tell me if you have trouble.
PS: I didn't check your 4 basic solutions and assumed them to be correct.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
