Impact Force of a Horizontal Moving Projectile
The discussion focuses on calculating the impact force of a 2"x4" projectile striking a solid cross beam at a velocity of 50 ft/sec. The initial approach using the formula F = KE/D is hindered by the unknown stopping distance after impact. Participants suggest determining the cross beam's deflection to estimate the force applied, with one user calculating a spring constant and resulting force of approximately 133,422 N. Further calculations reveal that the force could reach around 38,120.71 N, leading to significant deflection and stress on the beam, indicating it would likely bend under the impact. The conversation highlights the complexities of accurately modeling impact forces and material behavior in such scenarios.
JvandRWD
Member advised to use the homework template for posts in the homework sections of PF.
What is the correct way to calculate the impact force of a 2"x4" flying through the air and hitting a solid cross beam? The knowns are:
Velocity: 50 ft/sec
Distance To cross beam: 12 ft
2" x 4" Weight: 9 lbs
I don't know much the cross beam will deflect on impact, so the stopping distance is relatively unknown. I was planing on using F = KE/D = .5 * m * v2 / D, but without knowing the stopping distance after impact, I can't use it. Does anyone know how I should proceed?
Hello J, :welcome:
Funny you mention the 12 ft (irrelevant) but say nothing about the cross beam.
Nor about how the 2x4 is oriented wrt the beam. No drawing ?
But you have the right plan: find out how much that cross beam deflects. Load of course depends on acceleration, so you have to iterate a bit.
Likes JvandRWD
In most cases effective mass of the beam has to be taken into account as well .
There are analytical and numerical methods for dealing with this type of problem .
BvU said:
Hello J, :welcome:
I did a beam bending calculation on the cross beam, but I am unsure of what size force to apply. Is there a range you'd suggest? I started with a load of 214 lbf (950 N), and found that the beam will deflect .0235" (.5981mm). The impact location is also the direct center of the cross beam (974mm/2).
Is this homework ? If not,
I'm playing dumb and calculate a spring coefficient from that : ##k = F/dx = 950 / 5.8\times 10^{-4} = 1.6 \times 10^{6} ## N/m
If the kinetic energy of the 2x4 is converted to compression of a spring with such a spring constant you've found the deflection and thereby the force exerted on the beam -- if that's still in the elastic range of the brass. If not, it gets bent or dented...
I find yield strength 200+ MPa.
Likes JvandRWD
This is not homework. I did try the spring method you suggested and got the following:
##KE = PE, (.5(4.082kg)(15.24m/s)^{2})/x = .5(1.588 \times 10^{6} N/m)(x^{2}), x=.084 m##
Then I applied that distance to the spring constant and found my force to be ~133422N. This seems quite high for this. Am I doing something wrong?
That yield strength is from the verified material properties from the vendor.
I seem to remember other values: ##E_{\rm kin} ={1\over 2} 4.08 *15.2^2 = 474## J, so ##k ={ 2 E_{\rm kin} \over x^2 } \ \ \Rightarrow \ \ x = \sqrt {2 E_{\rm kin} \over k} = 24 ## mm.
So at the end the force would be 40 kN for the elastic spring scenario. Not all that realistic, but a ball-park figure
Ah yes, I forgot to get rid of the stopping distance in my original formula. So my force would be ~38120.71N, correct?
When I apply that force, I get 24mm of deflection, a Max Stress of 2791 MPa, which would mean my F.S. is .06. So the cross beam will be bent significantly?
I suppose that's what you get for stopping a 2x4 that moves at 50 km/h within 2.4 cm :redface:
