- 50,491
- 26,529
stevendaryl said:The Christoffel symbol is the one that most directly relates to the Newtonian concept of a gravitational field.
It's also the sense in which Einstein was using the term in the quotes GregAshmore gave.
GregAshmore said:First, with regard to treating the twin paradox as a problem of special relativity, it is my opinion that you do damage to the concept of relativity. According to the principle of relativity, every observer can legitimately consider himself to be at rest; there is no preference in principle for one frame over another. In terms of coordinate systems, the laws of nature have the same form in all coordinate systems, including the coordinate system in which any arbitrary observer is at rest. You have chosen to resolve the twin paradox by saying that the rocket twin cannot be considered at rest while undergoing proper acceleration. True, he cannot be considered to be at rest in an inertial frame while accelerating. Well, then, discuss the problem in terms of the non-inertial frame in which he is at rest. Until you do so, you have not satisfied the principle of relativity, and you have not resolved the paradox.
Second, it is not clear to me that Einstein successfully resolves the paradox in terms of general relativity. I understand that the math works out so that the traveling twin is younger. I do not challenge the calculation. I do wonder at the validity of the premise on which the calculations are based, though I do not go so far as to contradict it outright. The doubt is with regard to the physical reality of the gravitational field. Einstein himself felt the need to address that issue; hence his attempt to explain the field as the result of inductance originating in the distant stars. That explanation, lacking further detail, is unconvincing.
GregAshmore said:You have chosen to resolve the twin paradox by saying that the rocket twin cannot be considered at rest while undergoing proper acceleration. True, he cannot be considered to be at rest in an inertial frame while accelerating. Well, then, discuss the problem in terms of the non-inertial frame in which he is at rest. Until you do so, you have not satisfied the principle of relativity, and you have not resolved the paradox.
That's quite correct; that acceleration isn't as "relative" in the way Einstein suggested when he developed GR in 1907-1918 is perhaps one of the best "publicly known secrets" of modern science.GregAshmore said:As a result of the discussion which ensues from this post I hope to understand the implications of this statement: "Acceleration is not relative."
What are the broader implications of the statement that acceleration is not relative? Does this mean, as it certainly would appear to mean, that modern relativity is in this very important respect not Einsteinian relativity? Are there other implications as to the meaning of the principle of relativity?
stevendaryl said:Einstein's theory of General Relativity really doesn't make any mention of the distant stars.
stevendaryl said:That's Mach's principle, that the concepts of rotation and acceleration should be relative to the distant stars. Einstein hoped that his theory would satisfy Mach's principle, but it doesn't.
PeterDonis said:I know there have been long PF threads on this before, and I don't want to start another one, but I don't think this claim is a slam dunk either way. For a good exposition of the view that GR *does* embody Mach's Principle in at least some form, see Cuifolini & Wheeler's book Gravitation and Inertia.
stevendaryl said:Well, the sense in which it doesn't satisfy Mach's principle is that in flat spacetime, there are still inertial forces and there's still a difference between rotating frames and nonrotating frames, even though there are no distant stars for the rotation or acceleration to be relative to.
Yes, you did. I didn't appreciate the qualification, in large part because I did not understand it. There is another reason that I did not appreciate it, which I'll mention later in this post.DaleSpam said:Which is why I did qualify it, at length, in the post you referenced earlier.
Whenever a frame is privileged with respect to other frames, the principle of relativity is violated.DaleSpam said:I think that your opinion is wrong in this case. The first postulate of special relativity is expressly stated in terms of inertial frames. That postulate was later generalized for general relativity, but for problems in special relativity it is reasonable to treat inertial frames as priveliged according to the first postulate.
I don't know enough to have a preference. I may get to that point; we'll see. Thanks for the offer.DaleSpam said:You are right to be concerned about this. I think that the modern resolution has been to just leave it alone. The problem is that there are many quantities which could reasonably be called the "gravitational field" and none of them are so important as to clearly demand that they and not the others be called thus.
My personal preference is to call the Christoffel symbols the gravitational field, others prefer to use the Riemann curvature tensor or the Einstein tensor. Still others like to refer to the metric as the gravitational field. Before you can even discuss the "reality" of the field you need to decide what it is that you are talking about. If you have a preference then I would be glad to use your preference in the discussion.
GregAshmore said:Whenever a frame is privileged with respect to other frames, the principle of relativity is violated.
GregAshmore said:Recall, if you will, the objection raised by the doubter in Taylor & Wheeler, which I quoted earlier. His objection consists of two claims, though he thinks of them as one claim. The first claim is that the principle of relativity insists that the rocket twin can be treated as permanently at rest, and the Earth moving. The second claim is that in the scenario in which the Earth moves, the Earth twin will be younger upon his return. That is the paradox.
The first claim is correct.
GregAshmore said:The text never deals with the first claim, and therefore never shows that the second claim is incorrect.
GregAshmore said:Instead, the text asserts that it is the "change of direction" of the rocket twin that results in the younger age of that twin.
GregAshmore said:At the end of the section, this particular reader feels as though he has been tricked by sleight of hand--and frustrated because he is not capable of crafting a coherent refutation. And, in the case of T&W, insulted, to boot, as "objectors" are always made out to be buffoons.
GregAshmore said:the non-relativity of proper acceleration was given as the basis for the assertion that only the rocket twin moves, and thus for saying that the rocket twin must be the younger one of the two.
GregAshmore said:I suggest that an approach that is careful to explicitly treat each frame as permanently at rest (as separate cases, of course) would go a long way toward dispelling confusion and training minds to think correctly about relativity.
stevendaryl said:The principle of relativity is the claim that all inertial frames are equivalent. It doesn't violate that to say that noninertial frames are not equivalent to inertial frames.
For someone who knows what he is doing, the violation may be a harmless convenience. For someone who is in the process of training his mind to think in accordance with the principle of relativity, the violation makes it extremely difficult to discern between truth and error in one's understanding of the subject.
You guys have totally missed the point that T&W are making. They are using the doubter to show the inferiority (according to them) of explaining SR by using inertial frames. They prefer an explanation using what they call Proper Clocks as defined at the bottom of page 10 in section 1.3 called Events and Intervals Alone!. They are agreeing with the doubter. They want the reader to identify with the doubter and reject any explanation involving inertial frames and adopt their preferred explanation which is that you carry an inertial wristwatch between each pair of events to measure the Proper Time between those two events. They prefer this explanation because they say all observers will agree on the calculation of the Proper Time displayed on a Proper Clock even though they don't actually send a physical Proper Clock between the two events in question. But any observer can use their own rest frame to calculate the Proper Time from the coordinate times and coordinate positions. They are talking about the time-like spacetime interval.PeterDonis said:No, it isn't, because T&W specifically define the principle of relativity to only apply to inertial frames. If the objector was going to contest that, he would have to actually contest it; he would have to make some argument in favor of the generalized principle of relativity instead of the one that only applies to inertial frames. He doesn't; he just makes the flat claim that the rocket twin can be treated as being "at rest", which is simply false given the T&W definition.GregAshmore said:Recall, if you will, the objection raised by the doubter in Taylor & Wheeler, which I quoted earlier. His objection consists of two claims, though he thinks of them as one claim. The first claim is that the principle of relativity insists that the rocket twin can be treated as permanently at rest, and the Earth moving. The second claim is that in the scenario in which the Earth moves, the Earth twin will be younger upon his return. That is the paradox.
ghwellsjr said:They want the reader to identify with the doubter and reject any explanation involving inertial frames and adopt their preferred explanation which is that you carry an inertial wristwatch between each pair of events to measure the Proper Time between those two events.
ghwellsjr said:But any observer can use their own rest frame to calculate the Proper Time from the coordinate times and coordinate positions.
ghwellsjr said:This is not the first time someone has become confused by T&W's exclusive explanation of SR. I do not recommend the book, it does more harm than good.
PeterDonis said:There is also the issue of how to describe the scenario in a non-inertial frame in which the rocket twin is always at rest. In that frame, as we've seen, the twin firing his rocket causes a gravitational field to exist, which disappears when the rocket stops firing. That's a bit weird for a start. But also, there are issues with setting up coordinates in this non-inertial frame. There is no one unique way to do it [...]
Alain2.7183 said:In the several descriptions I've seen that use a fictitious gravitational field to resolve the twin paradox from the traveler's viewpoint, I didn't see any ambiguity anywhere ... the procedure gave a specific (unique) answer to the question of how much the home twin ages during the traveler's turnaround (according to the traveler).
This is simply not correct.GregAshmore said:Whenever a frame is privileged with respect to other frames, the principle of relativity is violated.
(my bold)Alain2.7183 said:In the several descriptions I've seen that use a fictitious gravitational field to resolve the twin paradox from the traveler's viewpoint, I didn't see any ambiguity anywhere ... the procedure gave a specific (unique) answer to the question of how much the home twin ages during the traveler's turnaround (according to the traveler).
Consistency is not the same a uniqueness. There are different, reasonable, choices for simultaneity for the accelerating twin. Each produces a different metric (though they converge near the 'time axis' represented by the accelerating twin), with different statements as to how much of the aging (of the inertial twin) occurs during turnaround (assuming e.g. coast, turn, coast). Further, the most common way this is presented will not work at all for a W shaped traveler trajectory (the simultaneity surfaces will intersect and multiply map the inertial twin world line, preventing you from having any coordinate chart in which to integrate proper time). So then you must use a different set of simultaneity surfaces to handle this case.Mentz114 said:(my bold)
Me neither. It looks completely consistent. Using the fictitious force to keep the 'rocket' twin stationary does not change the physics - viz. the traveling twin is non-inertial some of the time but the other one is always in free-fall. Therefore the traveling twin ages less as she should according to the other frames.
OK.PAllen said:Consistency is not the same a uniqueness.
If both worldlines are specified, is it possible to find a simultaneity choice that enables the WLs to be integrated ?There are different, reasonable, choices for simultaneity for the accelerating twin. Each produces a different metric (though they converge near the 'time axis' represented by the accelerating twin),
If the worldlines are specified, is the amount of ageing at turnarounds not uniquely defined ? I have to say that I'm not much interested in where the ageing occurs.with different statements as to how much of the aging (of the inertial twin) occurs during turnaround (assuming e.g. coast, turn, coast)
OK, but I was talking about the simplest scenario.Further, the most common way this is presented will not work at all for a W shaped traveler trajectory (the simultaneity surfaces will intersect and multiply map the inertial twin world line, preventing you from having any coordinate chart in which to integrate proper time). So then you must use a different set of simultaneity surfaces to handle this case.
Of course.Mentz114 said:If both worldlines are specified, is it possible to find a simultaneity choice that enables the WLs to be integrated ?
It is definitely not uniquely defined. Only the observables are uniquely defined. Simultaneity defined by the Einstein convention (two way light signal), and by a simultaneity based on spacelike geodesics 4-orthogonal to the traveling world line tangent, produce quite different answers. The former will work fine for the W trajectory. The latter is the one most commonly used, and will not work at all for the W trajectory.Mentz114 said:If the worldlines are specified, is the amount of ageing at turnarounds not uniquely defined ? I have to say that I'm not much interested in where the ageing occurs.
My point, having seen religious subservience to a convention that is only locally favored, is to stress the non-unuiqueness. Consistency is not a problem. But the non-uniqueness means there isn't one answer to how much ageing of the distant twin occur during turnaround. It really is just as silly as a short line on a piece of paper supposedly having a unique point of view about where the extra length of a longer line is.Mentz114 said:OK, but I was talking about the simplest scenario.
I understand you are advocating caution, but I was addressing the OP's question about a consistent treament of the twins in which the traveling twin remains stationary ( ie has a vertical worldline).
Thanks for the responses. I guess that finishes off the CADO nonsense.PAllen said:My point, having seen religious subservience to a convention that is only locally favored, is to stress the non-unuiqueness. Consistency is not a problem. But the non-uniqueness means there isn't one answer to how much ageing of the distant twin occur during turnaround. It really is just as silly as a short line on a piece of paper supposedly having a unique point of view about where the extra length of a longer line is.
No, that is not at all what bothers me. I am fully aware that the traveling twin is not inertial; of course a non-inertial frame cannot be treated as inertial. I am bothered that a theory which is only suited for treating inertial frames is used to deal with a problem involving a non-inertial frame.Mentz114 said:I have now realized that the OP was bothered because there is no treatment of the twins case with the traveling twin being inertial. As you and others have already pointed out, that is impossible.
Thanks for the clarification. I've never had a problem with that. We can get some useful results by including acceleration in SR. For instance, the Rindler frame, the Langevin frame, Born coordinates and probably others.GregAshmore said:No, that is not at all what bothers me. I am fully aware that the traveling twin is not inertial; of course a non-inertial frame cannot be treated as inertial. I am bothered that a theory which is only suited for treating inertial frames is used to deal with a problem involving a non-inertial frame.
No. That is the limited principle of relativity, for the special case of inertial frames. The principle of relativity states that the laws of physics are the same for all frames of reference.DaleSpam said:The principle of relativity states "The laws of physics are the same in all inertial frames of reference". So statements about non-inertial frames simply cannot violate it, anymore than statements about the price of steel can violate the principle of beans.
