Finding Points of Tangency for a Given Tangent Line Equation
In summary, the conversation discusses finding a point on the curve y^2 + x^3 = 9 that satisfies the equation of its tangent line, y + 6x = 13, with a slope of -6. The only point that satisfies this is (2,1), as substituting for x and y in both equations yields only one value. (-2,1) is not a point on the curve.
BrownianMan
134
The function of a line is y^2 + x^3 = 9. I calculated the slope of its tangent to be -3x^2/2y. The question asked us to find a point(s) so that the equation of its tangent line is y + 6x = 13. So it's slope must be -6 at that point.
I got (2,1) as a point. Are there more than one, or is that the only one?
well you will have 3x2/2y =6 such that x2=4y
So for each 'x' you pick, there will be a corresponding value of 'y' from that relation. Yes (2,1) is a point, so is (-2,1)
But if the point is (-2,1), then the equation for the tangent line can't be y + 6x = 13, because (-2,1) isn't on the line y + 6x = 13.
So here's what you know:
For the curve y^2 + x^3 = 9 (it's not a line, as you stated), y' = -3x^2/(2y).
The slope of the specified tangent line is -6.
Equating those values gives x^2 = 4y ==> x = +/-2sqrt(y)
Now substitute for x in the equation of the tangent line y = -6x + 13. This gives you two values of y, one of which is y = 1. The other is extraneous.
Now substitute this y value in the equation of your curve y^2 + x^3 = 9, and you get only one x-value.
(-2, 1) is not a point on your curve.
So the only point is (2,1) as I stated in my first post, right?
Right. (2, 1) and (2, -1) are both points on the graph of the curve, but only the first point has a tangent whose slope is -6.
Thank you so much!
1. What is implicit differentiation?
Implicit differentiation is a method used in calculus to find the derivative of a function where the dependent variable is not explicitly expressed in terms of the independent variable.
2. When is implicit differentiation used?
Implicit differentiation is commonly used when the equation of a curve cannot be easily solved for one variable, making it difficult to find the derivative using traditional methods.
3. How is implicit differentiation different from explicit differentiation?
Explicit differentiation involves finding the derivative of a function where the dependent variable is explicitly expressed in terms of the independent variable. Implicit differentiation, on the other hand, involves finding the derivative of a function where the dependent variable is not explicitly expressed in terms of the independent variable.
4. What are the steps for performing implicit differentiation?
The steps for performing implicit differentiation are as follows:
  1. Differentiate both sides of the equation with respect to the independent variable.
  2. For terms containing the dependent variable, use the chain rule.
  3. Solve for the derivative of the dependent variable.
5. What applications does implicit differentiation have?
Implicit differentiation has various applications in real-world problems, such as finding the rate of change in economics and physics, determining the slope of a curve in engineering, and analyzing optimization problems in business and finance.
