Implicit Differentiatoin question
  • Thread starter Thread starter compute_a_nerd
    Implicit
The discussion revolves around the implicit differentiation of the equation (x^3 y^4)^5 = x - y. The initial derivative calculated by Chris is incorrect, as pointed out by another participant. The correct derivative, as provided by the book, is y' = (1 - 15x^14y^20) / (1 + 20x^15y^19). The error stems from not properly differentiating the left side of the equation. Proper notation, such as using curly brackets for powers involving multiple characters, is also emphasized for clarity.
compute_a_nerd
Hello all.
I am given the equation (x^3 y^4)^5 = x-y
my derivative is 1/ (15x^2 20y^3(x^3y^4)^4)=y'
But the book says: y'=(1-15x^14y^20)/(1+20x^15y^19)
Where did I go wrong?
Thanks so much
Chris
You didn't differentiate the left side correctly. Try again.
Chris
You need to put curly brackets around all of your power if there is more than one character involved - like so,
y'=(1-15x^{14}y^{20})/(1+20x^{15}y^{19})
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
