Implicitly find the second derivative of x^2- y^3= 3
  • Thread starter Thread starter BraedenP
    Derive
BraedenP
Find \frac{d^2y}{dx^2} of the following equation:
x^2-y^3=3
Quotient Rule: \frac{d}{dx}(\frac{f(x)}{g(x)})=\frac{g(x)\cdot f^{'}(x)-f(x)\cdot g^{'}(x)}{g^2(x)}
I solved for the first derivative: \frac{2x}{3y^2}
But I'm stuck as to how I'd find the second derivative. I can generate answers, but none of them are correct.
How would I go about doing this?
x^2-y^3=3
You have
y' = \frac{2x}{3y^2}
Use the quotient rule (and chain rule) to find y''. Replace any occurrences of y' by what you already found so that y'' is in terms of x and y, but not y'.
Mark44 said:
You have
I'm so retarded. I forgot to equate the whole thing to y', and instead I equated it to 0 and solved for y' again. Ugh.
Thanks for your help!
From x^2- y^3= 3, 2x- 3y^2 y'= 0.
I would NOT solve for y' here. Instead, just differentiate "implicitely" again:
2- (6yy')y'- 3y^2y''= 0 so
y''= \frac{6y(y')^2- 2}{3y^2}
That is, in my opinion, a perfectly good answer but you could now use y'= 2x/(3y^2) to get y" in terms of x and y.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
