Improper integral x^(2) * e^(-x^2)
TsAmE
Show that \int_{0}^{\infty}x^{2}e^{-x^{2}}dx = \frac{1}{2}\int_{0}^{\infty}e^{-x^{2}}dx.
None.
I used substitution:
t = x^{2}
dx = \frac{dt}{2x}
\frac{1}{2}\int_{0}^{\infty}\sqrt{t}e^{-t}dx
Then tried using integration by parts but then I didnt get an answer and got stuck.
have you tried straight integartion by parts?
Try:
x^2*e^(-x^2) = [-0.5*x]*[-2*x*e^(-x^2)dx]
[-0.5*x] = u
[-2*x*e^(-x^2)dx] = dv
Tell us if you got it !
Good Luck :)
I tried integration by parts but it didnt work out. I only learn how to integrate e^(-x^2) next year.
How did you try? Did you try letting u= x and dv= xe^{-x^2}dx.
Try integration by parts with t=x, not t=x^2 !
I remind you:
integral(u*dv) = u*v - integral(v*du)
P.S.: If you learn in the next year how to get the anti-derivative of e^(-x^2), please tell us ;)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
