Improving Accuracy in Spring Constant Measurements: Tips and Considerations
  • Thread starter Thread starter Swamifez
To determine the spring constant (k) and the unstretched length (L_0) of a spring, a student conducted an experiment by hanging various masses and measuring the corresponding extensions, noting a measurement uncertainty of 0.2 inches. The relationship between extension and applied force is established through the equation kΔL = F, where F is the weight of the mass. The least squares method is recommended for fitting the data to find k, L_0, and their uncertainties, while also calculating the Chi-squared (χ²) value to assess the fit's accuracy. Chi-squared is defined as the sum of the squares of the distances from each data point to the fitting line, and the resulting value can be used to determine the associated probability from the chi-squared distribution. Accurate measurements and proper statistical analysis are crucial for improving the precision of spring constant determinations.
Swamifez
A student hangs masses on a spring and measures the spring's extension as a function of the applied force in order to find the spring constant k. Her measurements are:
Mass(kg): 200, 300, 400, 500, 600, 700, 800, 900
Extension (cm): 5.1, 5.5, 5.9, 6.8, 7.4, 7.5, 8.6, 9.4
There is an uncertainty of 0.2 inces in each measurment of the extension. The unccertainity in the masses is neglible. For a perfect string, the extension delta L of the spring will be related to the applied force by the relation kDelta L=F, where F=mg, and Delta L= L-L_0, L_0 is the unstretched length of the spring. Use these data and method of the least squares to find the spring constant k, the unstretched length of the spring L_0, and their uncertainties. Find Chi^2 for the fit and associated probability.
what is Chi^2?
Do you know how to do the fit? Just least squares... Write the chi², just by writing down the sum of the squares of the distances from each point to the fitting line. Now, minimize for the fitting parameters.
For the associated probability, you have to put the resulting chi^2 into the appropriate chi^2 distribution... but I don't know yet where your real problem is...
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
