Impulse from croquet mallete problem
  • Thread starter Thread starter in10sivkid
    Impulse
The discussion revolves around calculating the speed of a croquet ball after being struck by a mallet that delivers an impulse of 8.83 N*s. The impulse is equated to the change in momentum, which is zero initially since the ball is at rest. Using the formula for momentum (p = mv), where mass is given as 0.44 kg, the equation simplifies to 8.83 N*s = (0.44 kg) * V. Solving for V reveals that the calculation is straightforward. The key takeaway is that impulse directly relates to momentum, allowing for the determination of velocity.
in10sivkid
A croquet mallete delievers an impulse of 8.83 N*s to a .44 kg croquet ball initally at rest. what is the speed of the ball immediately after being struck?
ok so I = Ft = change in momentum
and they give us just a mass...
so that would help with p = mv to find velocity...
but this problem seems there are two unknowns i would either need to know the force or the time...but they don't give us either...
help?
all you need is the velocity, and you have I.
ok...how does having impulse help me with finding velocity
The impulse is the change in momentum, and the initial momentum is zero. Momentum is mass times velocity. You know the mass.
ok so essentially then then impulse = momentum since the initial momentum = 0
so 8.83 N*s = (.44 kg) * V
then solve for V...??
if so wow that was kinda easy
Looks good. Some of them are easy :smile:
