Impulsive Motion: Solving the Riddle
  • Thread starter Thread starter jimmykb
    Motion
The discussion revolves around the effects of an impulsive force applied to two bodies in contact, where one body acts as a pendulum. The key question is how the presence of an energy absorber between the two bodies affects the kinetic energy of the pendulum after the impulse is applied. It is noted that if the impulse remains the same, the kinetic energy of the pendulum will also remain the same, regardless of the absorber. However, the absorber will require more energy due to increased distance over which the force acts. The contact force measured by a sensor will differ with the absorber in place, as it affects the dynamics of the impulse transfer.
jimmykb
Dear all,
I get straight to the problem, that came out of a discussion with friends:
Two bodies are in contact with masses m_1 and m_2. Body m_2 is a pendulum. An impulsive force acts on one end of the body m_1.
(so an F\Delta t is applied).
The bodies are elastic, after the impulsive force they both have initial velocities.
As a result the impulse is equal to: I=F\Delta t=-m_1v_1+m_2v_2.
so the pendulum(body m_2) will have an initial kinetic energ equal to0.5m_2v_2^2. What will be the kinetic energy of the pendulum IF I place an absorber between the two bodies?
Is it going to be the same?? this riddle has been keeping me busy for a long time..
If I place a sensor to measure the contact force vs time between the bodies m_1 and m_2 what will be the difference if there is an energy absorber in between??Is the sensor going to measure the same impulse??
Thank you all in advance
If they are in contact for the time that the force is applied and they are rigid, they will have the same velocity after the force ends.
It will be the same if the impulse is the same. The momentum imparted depends only upon the applied Force and its duration. With the absorber in place, the application of that force for that time will require more energy (the force must act over a greater distance due to the compression of the absorber).
AM
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
