In which circumstances is work done?
  • Thread starter Thread starter mehmet
    Work Work done
Work is defined by the presence of displacement in the context of forces acting on an object. In the case of a book resting on a table, the forces are balanced, with gravitational force acting downwards and the normal force acting upwards, resulting in no net force and no work being done. For a rocket accelerating from a launch pad, two forces must be overcome: one related to its weight and another due to its mass. The discussion highlights the importance of clarifying whether the work is done by the rocket engine or on the rocket mass itself. Understanding these distinctions is crucial for accurately determining when work is performed.
mehmet
In which of the following circumstances is work done? If work is being done, what is the force acting on the object in each case?
a. A rocket accelerating from the launch pad
b. A ski-tow hauling a skier up a ski slope
c. A skier going down the slope at a steady speed
d. A book resting on a table
e. A rocket traveling through space at a steady velocity remote from any planet or stars.
Work done = F x d (force x distance)
So I have honestly no idea what kind of force is acting on the objects in each case, nor if work is being done. I attempted to identify the force for ‘d’ and I wrote the following: “work is being done and forces acting on the book are balanced, the weight of the book acts downwards and the normal reaction acts upwards which causes the book to rest on the table, this is gravitational force as it pulls the mass together and doesn’t push them apart. However, this makes no sense to me.
For "d", this part is correct. There are two forces acting on the book: Its weight (gravity) acting down and the normal force acting up. And they balance, so there's no net force.
But is work being done? For work to be done, there must be a displacement.
For a) ..
There are two forces that must be overcome. One is present even when the rocket is stationary on the pad. The other force is because the rocket has mass and the problem says it's accelerating. What force does the rocket generate to overcome these two?
mehmet said:
Problem Statement: In which of the following circumstances is work done?
It happens not to matter for answering the question, but the wording is rather loose. It should be clearer about whether we are discussing work done by the rocket engine or work done on the rocket mass (as opposed to its exhaust). If the engine were only firing strongly enough to keep the rocket moving at constant velocity, the engine would still be doing a great deal of work, but none on the rocket.
  • · Replies 57 ·
