Inclined plane problem help please
The discussion revolves around the dynamics of an object sliding down a frictionless inclined plane with a time-dependent angle defined by angular velocity. The equation derived for velocity shows a negative value, raising questions about its physical interpretation, particularly at t=0 when the angle is zero. Participants clarify that the negative velocity arises from the choice of coordinate system and the sign convention for gravitational acceleration. Additionally, it is suggested that the initial velocity at t=0 reflects potential energy rather than kinetic energy, emphasizing the need to consider energy conservation principles for accurate velocity calculations. The conversation highlights the complexities of analyzing motion on a rotating inclined plane.
Vatsa
If the angle of a frictionless inclined plane 'a' is such that a=wt
where w is angular velocity and a is a function of t
and an object is sliding down that plane then...
if m is the mass of the object
m(dv/dt)=mgsin(wt)
solving for v i got
v=(-gcos(wt)/w)
Why is the velocity negative and Why is that when i substitute t=0 v is greater than 0?
Hello Vatsa
What is the question asking for?
Can you please post the complete question , ?
Well...i just like solving problems i come up with...
So suppose you have a rotating inclined plane and the angle of inclination is a function of time such that...angle 'x'=angular velocity(w)*time(t)
now mgsin(x) is the horizotal component of g so the body on the frictionless inclined plane experiences a horizontal force=mgsin(x)..let the velocity along the incline plane be v
where m is the mass of the body
so...
m(dv/dt)=mgsin(x)
solving for v i got the above result...
my question is that even at t=0 why is there velocity..because at t=0 angle=0 and why is the velocity negative?
As the slope and mass are rotating about the bottom of the slope isn't there also a Centrifugal force acting up the slope?
and when you frame the equation , integrate it voila!
I'm not really sure, but I think you are not using the exact formula, the equation: mgsin(x), is not giving you the velocity, instead, is giving you the potencial energy of the body, that is why with t=0 gives you a value, because, while stopped, the body has potential energy instead of cinectic energy. If you want to find the velocity, you have to do the variation of the mechanichal energy so it will be: Em= Emf-Emi⇔Em= (Ecf+Epf)-(Eci+Epi)⇔Em=Ecf-Emi (because Epf=0 and Eci=0). The value is negative, because g=-9,8m/s.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
