Increasing Stationary Radio's Reception
  • Thread starter Thread starter tpluss
    Increasing
To enhance FM radio reception, optimizing the orientation of the existing small wire antenna can significantly improve signal strength. Experimenting with the antenna's position relative to metallic objects may also yield better results. A folded dipole antenna is recommended for improved reception and can be easily purchased at electronics stores. Placing the antenna near a window or an external wall free from conductive materials can further enhance signal quality. For advanced setups, consider mounting an external dipole antenna alongside a TV antenna and ensuring a good ground for the receiver.
tpluss
A stereo receives its FM radio reception from a small wire strewn out the back. How do I increase the reception?
Would I need a bigger wire, longer wire, or is there some other way to increase its reception?
The wire is removable; it clips into a metallic contact built into the stereo
If your radio has a signal-strength indicator, experiment with the orientation of the antenna to optimize the signal. You may find that moving the antenna nearer to or farther from some metallic object can affect the signal strength, too.
A good FM antenna is a folded dipole -- kind of a T-looking thing with two symmetric wires at the bottom, like this:
http://www.electronics-radio.com/articles/radio/antennas/dipole/folded_dipole.gif
You can buy them at Radio Shack and most electronics and TV stores. Once you have a reasonable antenna like that, the best reception is to find a place that gets a pretty good signal, like a window or an external wall that does not have anything conducting in it (external stucco finishes often have chicken wire in them for strength). Usually if you just tack the folded dipole antenna on one of your walls above the stereo, it will pick up signals pretty well.
Alternately, you can have an external dipole antenna mounted on your external TV antenna (if you have one), and run balanced stripline cable down into your house/condo along with the TV cable.
Have a good ground for the receiver.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
