Increasing the speed of Barlow's wheel
To increase the speed of Barlow's wheel, several methods can be considered, including increasing current, radius, magnetic field strength, and reducing friction. The discussion raises questions about the relationship between radius and angular velocity, noting that increasing radius can lead to increased torque but may also complicate the angular velocity equation. The use of an electromagnet instead of a permanent magnet is suggested to enhance revolution speed, as it can provide a stronger magnetic force without reversing the rotation direction when current polarity changes. However, concerns about increased friction with a larger radius and the overall impact on angular velocity are highlighted. Understanding the interplay between force, torque, and angular velocity is crucial for optimizing the wheel's performance.
NooDota
Hello, I have a problem about Barlow's wheel experiment with several questions. One of them is how to increase the angular velocity for the wheel.
I can either:
1. Increase the current
2. Increase the radius
3. Increase the strength of the magnetic field
4. Decrease friction
Are there any other ways to increase the speed?
Also, Wikipedia says that using an electro-magnet instead of a permanent magnet will cause more rapid revolution, I don't see why, can someone explain this?
"The points of the wheel, R, dip into mercury contained in a groove hollowed in the stand. A more rapid revolution will be obtained if a small electro-magnet be substituted for a steel magnet, as is shown in the cut. The electro-magnet is fixed to the stand, and included in the circuit with the spur-wheel, so that the current flows through them in succession. Hence the direction of the rotation will not be changed by reversing that of the current; since the polarity of the electromagnet will also be reversed."
https://en.wikipedia.org/wiki/Barlow's_wheel
2. Homework Equations
Are you sure increasing the radius will increase angular velocity? Also, how do you increase the radius without increasing mass and therefore friction?
Maybe the electromagnet is stronger.
Actually I don't know if it'll increase the angular velocity. It'll increase the force acting on the wheel, but I guess it'll also increase friction, I don't know which one would be stronger.
It's been sometime since I solved anything related to rotation, so any help is appreciated.
Also, dumb question.
F = I*r*B suggests that increasing r, would increase the force and thus the rotation, right?
But w =v/r suggests that increasing r, would decrease the angular velocity?
What am I doing wrong?
Torque is force multiplied with distance from the center (an exact treatment would need an integral), so doubling the radius gives four times the torque. The relation between force and angular velocity can be complicated.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
