Index of a critical point in a vecor field
logarithmic
This is from Henle's Combinatorial Introduction to Topology, section 9 question 2d).
Here's the phase portrait: http://img69.imageshack.us/img69/70/phasepor.jpg
Find the index of the point in the center of that picture.
I used the fact that index = 1 + (e - h)/2, where e = number of elliptic sectors, and h = number of hyperbolic sectors.
In the picture, only D is elliptic, so e = 1, and B, E, F are hyperbolic, so h = 3, which gives index = 0. (A and C are parabolic sectors and don't count for the purposes of finding the index.)
The correct answer is -2. Which can be confirmed by noting that if we pick "pointing upwards" as a reference direction, only at X and Y does it point upwards, and at both these places there is a clockwise turn (a turn in the negative direction), so index = -2.
What's wrong with the first method?
Are you trying to compute the winding number here? You can't just pick two points on a circle around the critical point and note the direction that the vector is turning to do that. You need to follow the complete circle and keep track of the total angle swept out by the vector field. If you do this for your diagram, you'll find that that the winding number is zero. For example, if you follow the curve from X to Y, you'll find that the angle swept is 0, not 2\pi.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
