Induced current from changing magnetic field
The discussion focuses on calculating induced electromotive force (emf) from a changing magnetic field using the equation emf = -d(Φ)/dt, where Φ represents magnetic flux. The user expresses confusion regarding multiple derivatives related to current (i), radius (R), and area (A). It is clarified that to find the total flux, one must integrate, as B varies with R, while A and R remain constant over time. The only variable changing with time is the current (i). This understanding is crucial for solving the problem effectively.
iharuyuki
emf = i (induced) R
emf = - d(Ф)/dt
Ф = B (dot) A
B = μi/(4piR)
emf = - d(Ф)/dt
emf = - d( B (dot) A )/dt
emf = - d[ (μi/(4piR) * A ]/dt, A and B are perpendicular
Really not sure how to proceed from here as there are multiple derivatives (di/dt dR/dt and dA/dt) that I don't quite get.
Thank you very much.
You have to calculate the total flux φ through the loop. Since B is a function of R, you have to integrate to find the total flux, which will be a function of i. In terms of your question about time derivatives, the only thing changing with time is i. A and R are constant in time.
Got it! Thank you very much.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
