Induced magnetic flux through a coil
The discussion centers on calculating the total magnetic flux through a circular coil with 100 turns in response to a time-varying external magnetic flux density applied along the z-axis. The total magnetic flux is expressed as a function of the external magnetic flux and the induced flux, with the equation Φt = BA - Φi. The challenge lies in determining the induced magnetic flux, which requires knowledge of how the magnetic flux density B varies over time. The provided formula for B complicates the process, as it remains a variable dependent on time. The relationship between induced EMF and magnetic flux is highlighted, emphasizing the need to derive flux from the induced EMF.
Gnarlywhale
A circular conducting coil with N=100 turns and radius "r" is oriented in the xy plane. The leads of the coil are connected to a circuit with resistance "R." A time varying external magnetic flux density "B" is applied along the z-axis.
What is the total magnetic flux through the coil as a function of time?
Φ = BA
Φt = Φb - Φi
Φt = BA - Φi
(where Φt is the total magnetic flux through the coil, Φb is the externally applied magnetic flux and Φi is flux induced by lenz's law).
I am aware that there is an induced magnetic flux but cannot figure out how to determine it from the external magnetic flux. Is there just some equation I can't seem to locate?
Are you sure that's the whole problem? You can't determine the induced magnetic flux unless you know how B varies with time, because induced EMF is equal to negative the change the magnetic flux.
They do give you a formula for B,
B = Bi(1 - 3(t/ti)^2 + (t/ti)^3)
Everything is still left as a variable.
So from this then, E = -N(dΦ/dt) = -100*Bi(1 - 3(t/ti)^2 + (t/ti)^3) ?
And then how do I get flux from this emf?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
