Inductance and Capacitance per Temperature
1 reply · 8K views
americanforest
I am studying the relationship between transmission speed in a Transmission Cable and the temperature of the cable. This speed is given by (as per discussion in the Feynman lectures)
[tex]v=\frac{1}{\sqrt{LC}}[/tex] where
  • [tex]L[/tex] is the inductance per unit length
  • [tex]C[/tex] is the capacitance per unit length
Does anyone know how the inductance and capacitance are expected to vary with temperature? The range examined in the experiment is approximately 20-50 degrees Celsius.
How much it will change basically depends on the properties of the dielectric (I am assuming you are referring to a coaxial cable).
The change should be very small assuming one of the more common dielectric is used, e.g. PTFE etc. I doubt creep will be much of an issue in such a small temperature range.
Also, if the range in question includes room temperature you should be able to find this data in a datasheet, they typically list data from -50 to +80 degrees C or so, at least if the cable conforms to military specs (and most coaxes do)
