How Does Inductor Behavior Affect Circuit Current at t = 0.224 s?
In summary, at t=0, when the switch is closed, the inductor current is 1.038 A and the switch current is 3.497 A.
christianerik
pic : http://s982.photobucket.com/albums/ae310/christianerik/?action=view&current=untitled.jpg
If the switch is closed at t = 0, find the
current in the inductor at t = 0.224 s. Answer
in units of A.
Find the current in the switch at that same
time.
I know that i must use i = V/R(1 - e^-t/L/R) but can't seem to get the right answer.
Any help is appreciated...5 ohms
-------------^^^^^^^------I
I.......I
I...10 ohms...1.4 H...I
I------^^^^^^^^---&&&&--I
I.......I
I...S...30 V...5 ohms.I
I-------/..---I I----^^^^^--I3. The Attempt at a Solution
i = V/R(1 - e^-t/L/R + V/5 = (30 - V)/5
(V/10)( 1 - e^-(0.224*10/1.4) + V/5 = -V/5 + 6
0.1V(0.798)+0.4V = 6
(0.4+0.0798)V = 6
V = 6/0.4798 = 12.5 v
The inductor current at t = 0.224 s
i = (12.5/10)[ 1 - e^-(0.224(10/1.4) ]
i = 0.9976 A
The switch current:
Is = i + V/5 = 0.9976 + 12.5/5 = 3.497 AWhat am I doing wrong?
At t = 0, you have to find out the voltage across LR circuit.
When the switch is open, what is the total resistance of the circuit? Note that when there is no current or a steady current, L has no reactance.
At t = 0, when the switch is closed, find the current drawn from the source.
Then find the voltage across LR branch.
Then using relevant equation find the current t given time t.
i thought that was what i was doing
12.5 volt across LR branch is not the voltage at t = 0.
hmmm... I calculated 16.52?
Show your calculation.
v=30-30(e^(-.244(1.4/5)
No. It is not correct. Work out according to my post#2
I got one answ... I(0.224) = 1.2*(1 - e^-2) = 1.038 A
5 + 5*10/(5 + 10) = 8.33
30/8.33 = 3.6 A
5*10/(5 + 10)=3.33
3.33*3.6 = 12 V
12/10 = 1.2 A
so I have that now how would I find the current in the switch at that same
time?
Use law of conservation of current.
How did you write this step?
1. What is inductance?
Inductance is a property of an electrical circuit that describes the ability of the circuit to resist changes in current. It is measured in units called henries (H) and is represented by the symbol L.
2. How does inductance affect an RL circuit?
In an RL (resistor-inductor) circuit, inductance causes the current to lag behind the voltage. This is because the inductor resists changes in current, so it takes time for the current to build up to its maximum value.
3. What is the role of inductors in RL circuits?
Inductors are used in RL circuits to control the flow of current and to store energy. They also help to smooth out any fluctuations in the current.
4. How is inductance calculated in an RL circuit?
The inductance in an RL circuit can be calculated using the formula L = V/I, where L is the inductance in henries, V is the voltage, and I is the current. It can also be calculated using the formula L = NΦ/I, where N is the number of turns in the inductor, Φ is the magnetic flux, and I is the current.
5. What are some real-world applications of RL circuits?
RL circuits are used in a variety of electronic devices, such as transformers, motors, and generators. They are also used in power transmission systems to regulate the flow of electricity and prevent power surges.
