Induction heating of a cylinder
The calculations for induction heating of a metallic cylinder inside a solenoid using the formula B = μni were found to be incorrect, as this expression is only valid in static cases. The discussion highlighted the need for a more complex expression involving Bessel functions to accurately describe the magnetic field in a time-varying scenario. The initial power calculation yielded unrealistic results, prompting a reevaluation of the E-field derivation from Maxwell's equations. Concerns about the skin effect not appearing in the calculations were also raised, emphasizing the complexity of the induction heating process. The issue was resolved by recognizing the need for a more sophisticated approach to the magnetic field representation.
Toftarn
Hello!
I am making som calculations on induction heating of a metallic cylinder inside
a solenoid through which an AC current passes, but the answer I get seems to
be completely unrealistic (10 kW with a 50 Hz, 5 Amps, 230 V rms), but I can't seem
to find my mistake.
What I think is wrong is the expression for the magnetic field inside the solenoid. I
have used
B = \mu n i
But is this really correct for a time varying field?
As far as I know it is derived using amperes law in the static case when the displacement
current is zero, but I haven't found any passing comment or remark or anything anywhere
that this equation is valid only in the static case. So is this formula correct even in the
time varying (sinusoidal) case? If not, what should it be replaced by?
Basically, what I did for the rest of the calculation was simply to get the E-field by starting
from the maxwell equation
\nabla \times \vec{E} = -\frac{\partial \vec{B}}{\partial t}
and integrating both sides over a circle of radius r. The righthand side was simplified using the expression
for the B-field above, and the left hand side was simplified using Stoke's Theorem to obtain
an expression for the E-field at radius r from the cylinder axis.
Then I calculated the power from
P = \iiint_{\text{cylinder}}{\sigma E^2 \text{dV}}
Another thing that worries me is that I find that the E-field is proportional to the distance
r to the cylinder axis. When I read about induction heating on the internet the skin effect is
always mentioned, but it didn't pop out my calculations anywhere... But on the other hand,
these calculations came straight from Maxwell's equations so I find it hard to believe that they are completely wrong...
Science news on Phys.org
First, 10kW out of 5A at 230V is impossible.
An induction heater is working pretty much like an ordinary transformer. You have a primary winding and a secondary winding. However, the secondary is the one you want to heat up instead of transfer electric current through a lamp or a AC motor.
Vidar
Okay, I figured it out. It turns out the problem was that the magnetic field inside the solenoid
was not given by that expression for B, but was actually given by a rather intricate expression
with bessel functions and such.
Anyway, here is a link to an article discussing just this, if anyone should be interested :P
http://jap.aip.org/resource/1/japiau/v17/i3/p195_s1
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
