Why does the resistance of an inductor vary with frequency?
In summary, an inductor and a straight wire differ in terms of their impedance, with the inductor having a changing impedance with frequency and the straight wire having a constant impedance. Inductors are designed to have specific characteristics, such as higher inductance, and can be created using different methods, such as winding wire in a coil or using a magnetic core. The resistance of an inductor also varies with frequency due to factors such as the magnetic core, skin effect, radiation, and eddy currents. In RF circuits, a length of PC board conductor track can be used as an inductor, and smith chart techniques can be helpful.
ragavcit
Hi,
How does an INDUCTOR AND A STRAIGHT WIRE differ?how come the resistance offered by an inductor changes with frequency??
This should help as an introduction:
http://en.wikipedia.org/wiki/Inductor
And it's the inductor's "impedance" that changes with frequency, not its "resistance". Welcome to the PF, BTW.
Any length of circuit has an inductance. Now, when designing an inductor, you may want special characteristics, for instance a higher inductance, especially at frequencies <1GHz.
A first step is to wind wire in the form of a coil. The consequence is that turns interact with another, in an additive way because currents close to another are in the same direction. Then, the same current flowing in N turns creates a vector potential A which is multiplied by N. The time variation of A gives the potential gradient along the wire, which is also multiplied by N. And as the potential sums over N turns, the inductance is multiplied by N².
Another step is to use a magnetic core, which helps the induction flow. As the flux increases, so does the inductance.
Designing an inductor is really nothing obvious. Constraints can be radically different: frequency, maximum current, AC or mainly DC, high voltage, precise value... So materials, forms, performances differ a lot.
Resistance (the real or lossy part of the impedance, the imaginary being the reactance) also varies with frequency. Causes are plentiful and difficult to find and evaluate. The magnetic core, if present, is an important one. Skin effect can be another. Radiation can exist. Less obvious, you can have eddy currents within the wires themselves.
Very few books are good for inductors. As the company still existed, RTC edited a very good guide for inductor design - probably impossible to find now. You may try at other core manufacturers.
Radio-ham books often contain chapters for inductor design. They make more sense than academic books.
just as a matter of interest. in many RF circuits , big inductors are not useful. so they just "draw" a length of PC board conductor track on the pc board and it serves as an indcutor. smith chart techniques become useful.
1. What is an inductor?
An inductor is a passive electronic component that stores energy in the form of a magnetic field when current flows through it. It is typically made of a coil of wire and is used in a variety of electronic devices.
2. How does an inductor work?
When current flows through the coil of an inductor, it creates a magnetic field. This magnetic field then stores energy, which is released when the current stops flowing or changes direction. This energy can be used to smooth out fluctuations in current or voltage in a circuit.
3. What is the difference between an inductor and a straight wire?
An inductor is a specific type of electronic component, while a straight wire is a general term for a conductor that is not coiled or shaped in any way. Inductors are designed to store energy in a magnetic field, while straight wires are used to conduct electricity.
4. How is an inductor used in electronic devices?
Inductors are commonly used in electronic devices to regulate current or voltage levels, filter out noise or other unwanted signals, and store energy. They are also used in electronic components such as transformers and motors.
5. Can an inductor be used in both AC and DC circuits?
Yes, inductors can be used in both AC (alternating current) and DC (direct current) circuits. In AC circuits, inductors are used to smooth out fluctuations in current and voltage, while in DC circuits they can be used for energy storage or to limit the rate of change of current.
  • Electrical Engineering
