Inelastic Collision of 2 Carts - Displacement
A 15.0 kg toy cart collides head-on with a 10.0 kg cart, resulting in an inelastic collision where they stick together. The initial velocities are 5.5 m/s to the right for the first cart and 4.0 m/s to the left for the second cart. After the collision, the combined velocity is calculated to be 1.7 m/s. The frictional force, determined by the coefficient of friction of 0.40, results in a deceleration of 3.92 m/s². The carts slide a distance of 0.37 meters from the collision point before coming to a stop.
testme
A 15.0 kg toy cart is traveling at 5.5 m/s to the right when it collides head on with a 10.0 kg cart traveling at 4.0 m/s to the left. The objects collide and stick togethere. The coefficient of friction between the wheels of the cart and the floor is 0.40. How far will the carts slide from the location of the collision?
ma = 15 kg
va = 5.5 m/s
mb = 10 kg
vb = 4.0 m/s
μ = 0.4
Assuming right is positive.
mava + mbvb = ma+b * va+b
Fnet = ma
v2^2 = v1^2 + 2ad
15(5.5) + 10(-4) = 25 * va+b
42.5 = 25 * va+b
va+b = 1.7 m/s
Fnet = ma
Ff = ma
Fnμ = ma
- Since there is no vertical acceleration Fn = Fg
9.8(0.4) = a
a = -3.92 m/s
this is where I get stuck
Edit: I tried doing this but I'm not sure if I'm right.
v2^2 = v1^2 + 2ad
0 = (1.7)^2 + 2(-3.92)d
-2.89 = -7.84d
d = 0.37 m
Yup. That works :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
