Inelastic relativistic collision
In an inelastic relativistic collision involving a particle with rest mass m_{0} moving at 0.8c and another particle with rest mass 3m_{0} at rest, conservation laws for total energy and quadrimpulse are applicable. The discussion emphasizes the importance of recognizing conserved quantities to solve the problem, suggesting the use of a reference frame centered on the moving particle. Participants are encouraged to express the total energy before and after the collision to derive necessary equations. The concept of quadrimpulse is clarified as a four-dimensional vector that generalizes the traditional momentum vector, integrating space and time into a unified framework. Understanding these principles is crucial for accurately determining the final rest mass of the combined particle post-collision.
armandowww
A particle with rest mass m_{0} moves at a speed of 0,8c. It's going to collide with a particle with rest mass 3m_{0}. If the latter was standing still before impact and if the collision is completely inelastic, what are the conservation laws valid? What is the final single particle rest mass?
What have you tried so far?
In my opinion, the total energy and the quadrimpulse must conserve. We can use a reference frame system centered in the first particle and consider the target particle as coming toward the origin in relative motion...
quadrimpulse? What's that? I hope it's a typo...
Meanwhile, write down an expression for the total energy of the system before and after the collision, that should get you one of the two equations you need.
Certainly the key to the problem is recognize what is physically being conserved.
Then, if you think geometrically, your math problem can be solved by drawing the appropriate triangle [for this inelastic collision] and realizing that you are essentially using the analogue of the law of cosines.
I was taught that, in restrict relativity, quadrimpulse is introduced as a four-dimensional vector resulting on the generalization of common momentum vector which, on the contrary, is featured by tri-dimensions.
Its formal expression could be given as: \underline{p}\equiv \left(m\vec{v},mc\right)\equiv \left(\vec{p},mc\right). This definition remainds to the famous issue that space (3D) and time (1D) are not to be considered apart any more, because they are interrelated each other and behave as as a whole, the space-time (4D).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
