Inequality of arithmetic and geometric means
The discussion centers on finding the maximum value of the expression 2(√(1-a^2)) + 2a, with participants suggesting the use of the inequality of arithmetic and geometric means. One contributor proposes using calculus to determine critical points by calculating the derivative and identifying where it equals zero or is undefined. The derivative analysis indicates that potential maximums occur at a=0, -1, and 1, prompting a check of these values for the maximum output. Another participant suggests that the expression can be reformulated to utilize the arithmetic and geometric means more effectively, though they express uncertainty about the application. Overall, the conversation highlights the interplay between calculus and inequalities in maximizing the given expression.
Numeriprimi
Hey! I have this: 2(√(1-a^2 ))+ 2a
How to determine the maximum value of this?
I think good for this is Inequality of arithmetic and geometric means, but I don't know how use this, because I don't calculate with this yet.
So, have you got any ideas?
Poor Czech Numeriprimi... If you don't understand my primitive English, write, I will try to write this better ;-)
Mathematics news on Phys.org
Could be a Calculus derivative problem. Does this f(a)=2(√(1-a^2 ))+ 2a have a maximum or minimum?
Carrying that farther f(a)= 2(1- a^2)^{1/2}+ 2a has derivative f'(a)= -2(1- a^2)^{-1/2}+ 2. Any maximum (or minimum) must occur where that derivative is 0 or does not exist. It does not exist when a= 1 or -1 because in that case we have a 0 in the denominator. It is 0 when \sqrt{1- a^2}= 1 or a= 0.
Check the values of 2\sqrt{1- a^2}+ 2a at x= -1, 0, and 1 to see which is the maximum value.
Another way to look at this is to see that if y= 2\sqrt{1- a^2}+ 2a then y- 2a= 2\sqrt{1- a^2} and so y^2- 4ay+ 4a^2= 4- 4a^2 or 8a^2- 4ay+ y^2= 4 which is the graph of an ellipse with major and minor axes rotated from the coordinate axes.
Please, derivate no... I still have a few years time to learn this.
I need to use Inequality of arithmetic and geometric means, bud how?
Your expression has two parts, ##2\sqrt{1-a^2}## amd ##2a##.
If you are supposed to use arithmetic and geometric means, you need to find some quantities that give those arithmetic and geometric means.
For example if the quantities are ##x## and ##y## and the arithmetic mean is ##2a##, you have the equation ##(x+y)/2 = 2a##
And you have another equation for the geometric mean ...
Yes, i have this: n=4
And what now?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
