How Does the Triangle Inequality Apply to Complex Numbers?
In summary, the conversation discusses proving the inequality 2|z||w| <_ |z|^2 + |w|^2 using two different approaches. The first approach involves expanding the expression $(|z| - |w|)^2$ to get |z|^2 - 2|z| |w| + |w|^2 and using the fact that this must be greater than or equal to 0. The second approach uses the arithmetic geometric mean and rewrites the expressions in terms of real and imaginary parts. It then uses the fact that the arithmetic mean is always greater than or equal to the geometric mean.
Poirot1
245
let z,w be complex numbers. Prove:
Mathematics news on Phys.org
Well, you could note that $(|z| - |w|)^2 \geq 0$ and work from there.
0<_ (|z|-|w|)^2=|z|^2+|w|^2-2Re(zw*).
Ok so I can say Re(zw*)<_|zw*|=|zw| but that doesn't quite get me there.
They are both real numbers, so when you expand $(|z| - |w|)^2$ you get $|z|^2 - 2|z| |w| + |w|^2 \geq 0$, hence the result.
There is the alternative of using that
$$|z|^2 + |w|^2 = \Re^2 (z) + \Im^2 (z) + \Re^2 (w) + \Im^2(w)$$
and
$$2|z||w| = 2 \sqrt{\Re^2 (z) + \Im^2 (z) } \sqrt{\Re^2 (w) + \Im^2 (w)} = 2 \sqrt{(\Re^2 (z) + \Im^2 (z))(\Re^2 (w) + \Im^2 (w))}.$$
Now, $a = \Re^2 (z) + \Im^2 (z)$ is a positive real number, same as $b = \Re^2 (w) + \Im^2 (w)$. This is the arithmetic geometric mean written in a different way:
$$\frac{a+b}{2} \geq \sqrt{ab} \implies \frac{\Re^2 (z) + \Im^2 (z) + \Re^2 (w) + \Im^2(w)}{2} \geq \sqrt{(\Re^2 (z) + \Im^2 (z))(\Re^2 (w) + \Im^2 (w))}.$$
How did you get that $(|z| - |w|)^2 = |z|^2 + |w|^2 - 2 \Re (z \bar{w})$?
The inequality of complex numbers is a fundamental concept in mathematics that states the magnitude of a complex number is always less than or equal to the sum of the magnitudes of its real and imaginary parts. This can be expressed as:
|z| <_ |Re(z)| + |Im(z)|
where z is a complex number with real and imaginary parts Re(z) and Im(z), respectively.
Now, let us consider two complex numbers, z and w. By the triangle inequality, we know that |z + w| <_ |z| + |w|. We can rewrite this as:
|z + w|^2 <_ (|z| + |w|)^2
Expanding the left side, we get:
|z + w|^2 = (z + w)(z + w) = z^2 + 2zw + w^2
Similarly, expanding the right side, we get:
(|z| + |w|)^2 = (|z| + |w|)(|z| + |w|) = |z|^2 + 2|z||w| + |w|^2
Now, we can rewrite the original inequality as:
z^2 + 2zw + w^2 <_ |z|^2 + 2|z||w| + |w|^2
Subtracting z^2 and w^2 from both sides, we get:
2zw <_ 2|z||w|
Dividing both sides by 2, we get:
zw <_ |z||w|
Finally, we can rewrite this as:
Therefore, we have proved that 2|z||w| <_ |z|^2 + |w|^2, which is the inequality of complex numbers. This result is important in many areas of mathematics, including algebra, geometry, and analysis, and it provides a useful tool for solving problems involving complex numbers.
Related to How Does the Triangle Inequality Apply to Complex Numbers?
What is inequality of complex numbers?
Inequality of complex numbers refers to the comparison of two complex numbers using the greater than, less than, greater than or equal to, or less than or equal to symbols. This is done by comparing the real parts of the complex numbers first, and if they are equal, then comparing the imaginary parts.
How is inequality of complex numbers represented algebraically?
Inequality of complex numbers is represented algebraically using the inequality symbols (<, >, ≤, ≥) between two complex numbers. For example, if z1 = a + bi and z2 = c + di, then z1 > z2 means that a > c or if a = c, then b > d.
What is the geometric interpretation of inequality of complex numbers?
Geometrically, inequality of complex numbers can be represented on the complex plane. The complex numbers can be plotted as points on the plane, and the inequality symbols represent the relationship between the points. For example, if z1 = 3 + 2i and z2 = 1 + 4i, then z1 > z2 means that the point representing z1 is to the right of the point representing z2 on the complex plane.
How does the modulus of a complex number affect inequality?
The modulus (absolute value) of a complex number can affect inequality because it represents the distance of the complex number from the origin on the complex plane. If two complex numbers have the same real part, the one with a larger modulus will be considered greater.
Are there any special cases to consider when working with inequality of complex numbers?
Yes, when working with inequality of complex numbers, it is important to consider the cases where the real or imaginary parts are equal. In these cases, the inequality symbols may need to be adjusted to include the equal sign. For example, if z1 = 2 + 3i and z2 = 2 + 2i, then z1 ≥ z2 because the real parts are equal and 3 > 2 for the imaginary parts.
  • General Math
  • General Math
