MHB Prove Inequality Problem for Real Numbers $a, b, c$ with $a + b + c = 1$
  • Thread starter Thread starter anemone
    Inequality
The discussion focuses on proving the inequality involving real numbers \(a\), \(b\), and \(c\) such that \(a + b + c = 1\). The inequality states that \(\frac{1}{3^{a+1}} + \frac{1}{3^{b+1}} + \frac{1}{3^{c+1}} \ge \left(\frac{a}{3^a} + \frac{b}{3^b} + \frac{c}{3^c}\right)\). Participants are encouraged to explore potential methods for proving this inequality, including hints and approaches. The conversation includes a mix of solutions and clarifications regarding the mathematical expressions involved. The thread emphasizes the importance of understanding the relationship between the variables in the context of the given constraint.
anemone
MHB
POTW Director
Let $a,\,b$ and $c$ be real numbers such that $a+b+c=1$, prove that
$$\frac{1}{3^{a+1}}+\frac{1}{3^{b+1}}+\frac{1}{3^{c+1}}\ge \left(\frac{a}{3^a}+\frac{b}{3^b}+\frac{c}{3^c}\right)$$.
Mathematics news on Phys.org
Hint:
If $$a\ge b \ge c$$, then we would get $$\frac{1}{3^c}\ge \frac{1}{3^b} \ge \frac{1}{3^a}ᵃ$$.
My solution:
WLOG, let $$a\ge b \ge c$$ and hence $$\frac{1}{3^c}\ge \frac{1}{3^b} \ge \frac{1}{3^a}ᵃ$$.
Apply the Chebyshev's inequality we have:
$$\begin{align*}3\left(\frac{a}{3^a}+\frac{b}{3^b}+\frac{c}{3^c}\right)&\le \left(a+b+c\right)\left(\frac{1}{3^a}+\frac{1}{3^b}+\frac{1}{3^c}\right)\\&\le \left(1\right)\left(\frac{1}{3^a}+\frac{1}{3^b}+\frac{1}{3^c}\right)\end{align*}$$
and therefore
$$\frac{1}{3^{a+1}}+\frac{1}{3^{b+1}}+\frac{1}{3^{c+1}}\ge \left(\frac{a}{3^a}+\frac{b}{3^b}+\frac{c}{3^c}\right)$$ (Q.E.D.)
A small comment and question:
Hi, anemone
Thankyou so much for your indefatigable contributions to this interesting site!(Yes)
You, MarkFL et al. are really doing a great job. Thankyou so much!I have a small comment/question to this challenge.Maybe the inequality is not Chebyshev (statistics), but Cauchy-Schwarz (inner product)??Even if so, I do not understand how to use it in the context. If I define two vectors:\[\bar{u} = \begin{pmatrix} a\\ b\\ c \end{pmatrix}, \: \: \: \bar{v} = \begin{pmatrix} \ 1/3^a\\ 1/3^b \\ 1/3^c \end{pmatrix}\]then using the Cauchy-Schwarz inequality:
\[\left ( \sum_{i=1}^{n} u_iv_i\right )^2 \leq \left ( \sum_{j=1}^{n}u_j^2 \right )\left ( \sum_{k=1}^{n} v_k^2\right )\]
- I get:
\[\left ( \frac{a}{3^a}+\frac{b}{3^b}+\frac{c}{3^c} \right )^2 \leq \left ( a^2+b^2+c^2 \right )\left ( \frac{1}{3^{2a}} + \frac{1}{3^{2b}}+ \frac{1}{3^{2c}}\right )\]How can I ommit squaring?Thankyou in advance for clearing my confusion … ;)
anemone said:
My solution:
and therefore
Hi lfdahl(Smile),
The inequality formula that I used is the Chebyshev's inequality that says:
If $x_1\ge x_2\ge \cdots\ge x_n$ and $y_1\ge y_2\ge \cdots\ge y_n$, then the following inequality holds:
$$n\left(\sum_{i=1}^{n}x_i y_i\right) \ge \left(\sum_{i=1}^{n} x_i\right)\left(\sum_{i=1}^{n} y_i\right)$$
On the other hand, if $x_1\ge x_2\ge \cdots\ge x_n$ and $y_n\ge y_{n-1}\ge \cdots\ge y_1$ then we have:
$$n\left(\sum_{i=1}^{n}x_i y_i\right) \le \left(\sum_{i=1}^{n} x_i\right)\left(\sum_{i=1}^{n} y_i\right)$$
Hi, anemone!
Thankyou very much for the explanation. Oh, oh .. I guess, I still have a lot to learn :o
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
