Inertia and conservation of momentum
Inertia, defined by Newton's first law, states that an object at rest stays at rest and an object in motion stays in motion unless acted upon by an external force, which relates to the conservation of linear momentum as both concepts emphasize the persistence of motion. The law of conservation of linear momentum asserts that the total momentum of a closed system remains constant, linking directly to inertia as it describes the behavior of objects in motion. Similarly, Newton's first law for rotation introduces the concept of rotational inertia, or moment of inertia, which describes how mass distribution affects rotational motion. This rotational inertia is crucial for understanding the conservation of angular momentum, which states that the total angular momentum of a closed system remains constant when no external torques act on it. Together, these principles illustrate the fundamental relationship between inertia and the conservation laws in both linear and rotational dynamics.
Mt. Nixion
How are inertia (Newton's first law) and the law of conservation of linear momentum related? Also, how does Newton's first law for rotation (rotational inertia or moment of inertia) related to the law of conservation of angular momentum?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
