How to Find Psi(x,t) in an Infinite Potential Well?
natugnaro
Hi,
Particle of mass m is found in one-dimensional infinite potential well with walls 0<=x<=a.
In t=0 the normalized wave function is:
\psi(x,t=0)=A[1+Cos(\frac{\pi x}{a})]Sin(\frac{2 \pi x}{a})
find psi(x,t)
\psi(x,t)=\sum C_{n} e^{\frac{-iE_{n}t}{\hbar}}\phi_{n}(x)
C_{n}=\int^{a}_{0}\phi_{n}(x)\psi(x)dx
C_{n}=\int^{a}_{0}Sin(\frac{n \pi x}{a})A[1+Cos(\frac{\pi x}{a})]Sin(\frac{2 \pi x}{a})dx
I could do the integral and find Cn coefficients, but it takes time.
Is there an easier way for findin psi(x,t) ?
natugnaro said:
Hi,
find psi(x,t)
I don't think so, perhaps if you use tables of standard integrals or maple / mathematica.
Ok, thanks.
Just wanted to make shure I'm not missing something.
natugnaro said:
Ok, thanks.
there is standard integrals for ortonogal cos and sin integrals, if you want more hints.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
