Infinite well linear combo of states
galactic
A particle of mass m is trapped in a one-dimensional infinite square well running from x= -L/2 to L/2. The particle is in a linear combination of its ground state and first excited state such that its expectation value of momentum takes on its largest possible value at t=0.
I know the process of solving PDE's clear as day, that's not the issue. The problem is that I'm tripping myself out on how to write Ψ(x,t) as a linear combination of its ground state + first excited state.
My hunch is to approach the problem like this :
Ψ(x,t)=c1Ψ1(x,t)+c2Ψ2(x,t)
where 1 and 2 represent the ground state and first state, respectively
that momentum takes on the largest possible value at t=0 is confusing and not sure what to do.
Have you tried:
##\Psi(x,t)=c_1(t)\psi_1(x)+c_2(t)\psi_2(x)##
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
