Is dlπ/2 equivalent to dl/(dlπ/2)?
  • Thread starter Thread starter LCSphysicist
    infinitesimals
The discussion centers on the equivalence of dlπ/2 and dl/(dlπ/2), where dl represents an infinitesimal length. The limit as dl approaches zero shows that dl/(dlπ/2) equals 2/π, suggesting a form of equivalence. However, there is a distinction made between the two infinitesimals, as they are not equal but rather linearly dependent on dl. The confusion arises from the interpretation of equivalence versus equality in the context of infinitesimals. Ultimately, while they share a relationship, they are recognized as different entities in mathematical terms.
LCSphysicist
Is equivalent the infinitesimal segment and the semicircle with diameter equal to this infinitesimal segment?
l/(lpi/2)
dl = Infinitesimal length of the segment.
dlπ/2 = the semicircle length
lim dl-> zero
dl/(dlπ/2) = 2/π, no zero, so the answer would be yes.
But second the book, the answer is no, where am i wrong?
I see, actually I mistook same order and equivalence...
Not sure what you mean by equivalent but they are not equal, they are two different infinitesimals, one is ##dx=dl## and the other is ##dy= \frac{\pi}{2}dx=\frac{\pi}{2}dl##.
They are of the same order as you say, they are both linearly dependent on dl so you might say that in this sense they are equivalent.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
