Is Infinity a Concept or a Number?
  • Thread starter Thread starter romsofia
    Concept Infinity
Infinity is not a singular entity but rather encompasses various forms, behaving both as a concept and as a number depending on the context. In traditional number systems, infinity does not qualify as a number, as it leads to contradictions in arithmetic. However, alternative number systems, such as surreal and hyperreal numbers, can incorporate infinity as a numerical value. Additionally, infinity is utilized in concepts like cardinality and limits, further illustrating its dual nature. Ultimately, the discussion reveals that infinity cannot be confined to a single definition, as it manifests in multiple ways across different mathematical frameworks.
romsofia
Hey, is infinity a concept or an actual number?
This is a discussion with someone, I say it's a concept but then he brought up set theory, and I have no set theory knowledge whatsoever.
Mathematics news on Phys.org
Infinity does not behave according to ur laws of arithmetic(usual number)...
1/0 = inf
1= inf * 0
1= inf*(0+0)
1=2 (contradiction)
What is a number?
Answer:
An element of a particular number system.
A number system is a set, where you have defined some operations, i.e, "stuff" you can "do" with your elements. For example, you might pick any two elements, and according to some specified procedure associate a third element to your picked pair of elements.
Typical examples of such operations are "addition" and "multiplication" (Pick two numbers, add them, and gain a third number).
Now, in our "ordinary" number systems, there is no element that reasonably could be called "infinite". Thus, within these number systems, infinity is not a number.
However, it is perfectly possible to construct number systems in which infinity is a number as well.
Well, the most disturbing thing about infinity is that there are many different forms of it. Sometimes it behaves as a number, sometimes as a concept...
Infinity as a number:
- Surreal numbers
- Hyperreal numbers
(in the real numbers, infinity is certainly not a number!)
Infinity as concept:
- cardinality
- limits
Infinity as "points in the space":
- one-point compactification
- ordinals and cardinals
- projective space
So there are many different flavours of infinity. So the original question is actually not correct, since there is no one thing called infinity. There are many different object which are all called infinity...
- Surreal numbers
- Hyperreal numbers
- cardinality
- limits
- projective space
Wow I have been trying to explain what you just said!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
