Inflammable material carrying vehicles
  • Thread starter Thread starter phymathlover
    Material Vehicles
Special rubber tires on aircraft are designed to be slightly conductive to dissipate static electricity generated by friction, preventing sparks that could ignite fires. Similarly, vehicles transporting flammable materials often use metallic ropes to ground themselves while in motion. The discussion highlights that sparks occur when an electrostatic field becomes strong enough to cause air breakdown. Providing a conductive path, such as drag chains or conductive tires, helps drain these charges, enhancing safety during refueling. Overall, these measures are crucial for reducing fire risks associated with static electricity.
phymathlover
Special rubber tires are made slightly conducting, in aircrafts, to enable them to pass on charge (produced by friction) to the ground, as too much charge may result in a spark and hence cause a fire. This is apparently the same reason why some vehicles usually have metallic ropes touching the ground during motion especially when they carry inflammable materials. But I don't get how exactly the charge causes the spark.
Sparks are what you see when there is an air breakdown due to the strength of the electrostatic field (volts/meter) between two objects.
Providing a conductive path (drag chains, conductive tires, etc) allows the electrostatic charges to be drained ... thus the vehicle should not build up a static charge strong enough to spark. This makes it safer when refueling.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
